Old House Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 06:58 AM   #1
Rewards Points: 1,216
Old House Wiring
House 100 years old the knob and tube was replaced the year I don't know, when working with switches and outlets I find the insulation falls off when you move the wires to much, I tape them where they crack the best I can I don't think it good enough. Has anybody ever used shrink tube on the wires and can shrink tube be shrunk with a hairdryer? The wires are not brittle and are in good shape it's just the insulation. Replacing the wires would be a nightmare. Open to all suggestions.
COLDIRON is offline   Reply With Quote
Old 11-17-2010, 08:37 AM   #2
Licensed electrician
Rewards Points: 1,474
I have done this to a limited degree with heat shrink. You need a heat gun or a lighter or a small torch.
Old 11-17-2010, 10:40 AM   #3
Thanks Jim
Old 11-17-2010, 07:54 PM   #4
My 1948 home has some rubber and cotton covered romex wire installed. Its in good shape, except in the junction boxes where the air can get at it.
It was next to impossible to install new cable, so removed the cable clamps from the box. This allowed me to wrap electrical tape as close to the sheath as possible. Then I slipped heat shrink tubing over the tape.
After shrinking the tubing with a match, I replaced the cable clamps.
Old 11-17-2010, 09:19 PM   #5
joed's Avatar
Rewards Points: 12,362
Are you sure all the wires were replaced. Insulation doesn't go bad on new cables especially in switch boxes. In ceiling fixtures where heat is present it is more common. By new, I mean as far back as the 70s or even the 60s.
Old 11-17-2010, 10:57 PM   #6
Are you asking me or the OP? My place is 62 years old! (1948)
Old 11-18-2010, 06:18 AM   #7
Yes it has been replaced the insulation is like a black tar with looks like twine wrapped around it and it has colors but they are very hard to see,
red,white, black. Looks like something from the 50s. I think it might be bx hard to see in the boxes, but it looks like anti shorts at the hold down.
Old 11-18-2010, 08:10 AM   #8
joed's Avatar
Heat shrink will work. But I think this wire is older than you think and should be scheduled to be replaced. I am thinking they only replaced the K&T that was visible and easy to remove. The rest was left in the walls and ceilings.
Old 11-18-2010, 09:01 AM   #9
Thanks any and all comments welcome.
old house wiring...not code fisherman2001 Electrical 13 10-06-2009 07:30 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
