Old House - Old Wiring, Need Help!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 03:25 PM   #1
Old House - Old Wiring, Need help!!!
ok so i had a guy come and "install" a new medicine cabinet and light in my bathroom. well the old medicine cabinet had a light switch, plug, and light mounted on the side of it. so they guy i had "install" a new one just tosses it out and "installs" my new light and medicine cabinet with no power switch.. so its put in a bulb until it burns out and then replace it lol.. so i decided to tear it all out and do it myself. needless to say he wasnt paid lol.. anyways, i dont know anything about electric work. but i can see that the guy disconnected whatever wire was connected to the switch on the old cabinet and wired it straight to the new light.. there is only a black wire and a white wire by the way. like i said old house and old wiring... but to my question.. can i just simply cut the jumble of wires behind the light and bring the down to run into the bottom of the light switch and run new wire out of the top of the switch to the light? if that makes any sense at all.. i know im kind of rambling,, if it doesnt make sense just let me know and i will sit down and try to make more sense of it lol
jacobried is offline   Reply With Quote
Old 08-31-2011, 03:49 PM   #2
i added a photo to try to make more sense.. i used green and red so they would stand out... ok so i need to know how to wire a switch to install a light in the bathroom and still be able to have those wires run to the next room so the light will work in there.. can anyone help out??
Old 08-31-2011, 04:41 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
Stop what you are doing and call an electricain. You are dealing with knob and tube wiring. It is not to be extended or modified. Your medicine cabinet installer left a royal mess. You should not have those open splices in the wall. That whole circuit needs to be rewired.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-31-2011, 05:45 PM   #4
RST
DIY Homeowner
Rewards Points: 150
What he said! This isn't something to DIY.
RST is offline   Reply With Quote
Old 08-31-2011, 11:52 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I will agree with other guys just stop right there and have electrician come in and assit you on this one you can NOT modifed the old T&K set up at all and what more to compound the issue you have the wall open now so you have to bring it up to the date with the codewise.
The electrician will determed how far the oringal T&K is and see if any other comprised T&K conneciton or location and they will pull the NM cable and do the proper repairs as need to.
Now for the bathroom you will need it own circuit for the GFCI receptale this is very specfic in the NEC codé. { a 20 amp circuit is common }
Merci,
Marc
Old 09-01-2011, 12:09 AM   #6
Code05's Avatar
Rewards Points: 1,104
20 amp circuit to a bathroom is required.
Code05 is offline   Reply With Quote
Old 09-01-2011, 12:28 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,096
Wiring in a switch is easy enough,
Take the white wire out of the back of the lamp base,
Add some more white wire to this white wire,
run it to the switch and connect.
On other side of switch add another white wire,
Run wire wire back up to the lamp base,
And connect.
EASY.
BUT --
Do you want to keep it up to code ???
knob and tube wiring is risky,
and you have really opened up a B I G can of worms.
If you want to keep it up to code,
I suggest you consult with an electricain.
dmxtothemax is offline   Reply With Quote
Old 09-01-2011, 05:54 AM   #8
A "Handy Husband"
rjniles's Avatar
And connect.
EASY.
What you are suggesting is switching the neutral, a total code violation and dangerous. The OP needs an electricain as you also suggest.
Old 09-02-2011, 12:19 PM   #9
thank you to everyone, i will call an electrician lol... i figured it looked a mess when i took the wall out. i dont know anything about electrical work but i knew that didnt look no were near right.. so thanks again and i will have someone come and fix it the right way.
Old 09-02-2011, 12:23 PM   #10
Rewards Points: 6,652
Keep in mind, that it will be easier to do all electrical, to bring up to date now, since you are working on the bath, cost wise, than trying to do it piece meal over time. you can pull all of the Romex yourself. Or find an Electrician that will work alongside you, and let you help do the grunt work of helping to pull Romex, and they can assist in showing you how to connect switches & outlets, to help pass an inspection, if one is required for this scope of work.
Bad side is, since you have Knob & Tube, I am guessing that you still have a 60 amp fuse panel, somewhere.
Old 09-02-2011, 06:33 PM   #11
Please come back later, and let us know what the outcome was !
The Following User Says Thank You to dmxtothemax For This Useful Post:
Leah Frances (09-02-2011)
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 10:50 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 04:56 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
