Old House, Old Question On Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 09:49 PM   #1
Rewards Points: 97
old house, old question on gfci
i thought i will be able to find the answer with simple search as i am sure i am not alone in this situation but could not find the answer...
1. for 26 yr old house, what is the distance from the KITCHEN sink for which GFCI is a required?
conversely, what is the minimum distance (from kitchen sink) to a NON-gfci outlet
2. when we bought the house, the kitchen-counter outlets were not GFCI and we never changed....do we need to change before selling the house?
thanks
drgkjd is offline   Reply With Quote
Old 05-21-2013, 10:30 PM   #2
Rewards Points: 150
thanks
the inspection report will probably ask for all receptacles serving the countertops be GFI protected.
usair is offline   Reply With Quote
The Following User Says Thank You to usair For This Useful Post:
drgkjd (05-22-2013)
Old 05-21-2013, 11:00 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,456
thanks
Technically, that would be around the 1987-87-88 code cycle. You would normally be grandfathered to that... but doubtfull any of us remember/know that.
Practically speaking, especially if you can do it, put 1 or (2 if necessary) GFI's on your kitchen counters to protect all kitchen recepticals. Use 1 first in each circut to protect all and you'll be out only $10-$20.
As USAIR said, you'll get noticed in your buyers inspection... and regardless of whether youy are grandfathered legal, my experience is it freaks novice, unknowledgeable home buyers. They'll ask for the repair and an electrician will be 100-150 with a service call.
Plus that is a good safety measure in my opinion.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
drgkjd (05-22-2013)
Old 05-21-2013, 11:14 PM   #4
Rewards Points: 512
If you haven't updated the circuit, the non-GFCI is grandfathered. Nevertheless, I'd replace them.
Installation is the Reverse of Removal.
The Following User Says Thank You to sirsparksalot For This Useful Post:
drgkjd (05-22-2013)
Old 05-22-2013, 07:42 AM   #5
joed's Avatar
Rewards Points: 12,396
You don't need to do anything before selling the house. The buyers can request a bunch of stuff but you don't have to do anything.
Under current code all receptacles on the kitchen counter are GFCI. Under the code your house was built under no receptacles on the counter were required to be GFCI.
The Following User Says Thank You to joed For This Useful Post:
drgkjd (05-22-2013)
Old 05-22-2013, 11:19 AM   #6
Joed is dead on.... I'm just saying from a pragmatic sales standpoint, only my experience and opinion, lack of GFI scare alot of novice buyers (not you me or Joed). If you can preempt their possible request for GFI yourself for $20 (verse their request for GFI installed by a licenced electrician... and that's how it will be styled to mitigate RE agent liability), I think it is an economic and smart sales technique. (if you have to pay an electrician to do now... I guess it doesn't matter that much).
Sounds stupid... but I also advise that you clean-up and vacume your furnace. Seems to me if its dirty, half the time an inspector will say the unit should be inspected/certified by a licensed HVAC man. Then you're into service call costs.
Your home is a used home, with plenty of normal corrections to be found... and I just try to minimize what I consider to be transfer costs of trading/selling property.
mm11 (05-22-2013)
Old 05-22-2013, 02:25 PM   #7
Rewards Points: 97
the furnace (gas)--- not sure where to vacuum
GFCI- i think it is very simple just to replace the regular dup-out with GFCI
Old 05-22-2013, 03:04 PM   #8
In ref to the furnace.... it really is that simplistic.... if it doesn't look dirty, cobwebby, crappy.... you're already done.... you'd be surprized how bad some furnace rooms look.
(Actually, if ya know what your doing, I'll take off my burner and blower cover (the sheet metal covers/doors just kinda snap off) and vacume dust out of them... cost 0... but inspectors do not really inspect for burner adjustment etc.... but if it looks unkempt and crappy, they often advise it be certified by a specialist.... to cover themselves.)
EDIT: SEE OSO BELOW
Old 05-22-2013, 04:30 PM   #9
Oso954's Avatar
Rewards Points: 1,008
While you are at it, change the furnace filter.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
MTN REMODEL LLC (05-22-2013)
GFCI Question daveplot Electrical 11 06-10-2011 09:23 PM
GFCI with 12/2 wire Safety Question Coors Electrical 8 03-09-2010 04:53 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
GFCI Question dankreboot Electrical 5 08-06-2008 08:33 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 03:27 PM
