Old Fashion Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2014, 09:08 AM   #1
Rewards Points: 6
lilabadge
Looking for these old fashion push in breakers for a 1971 American Mobile Home.
lilabadge is offline   Reply With Quote
Old 10-26-2014, 10:48 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,732
Welcome to the forums.
Post up a thread in the electrical section. They will find them for you in a heartbeat is my guess.
Old 10-26-2014, 10:54 AM   #3
Rewards Points: 6
Looking for these old fashion push in breakers, from an American Mobile Home. The mobile home was manufactured in 1971.
Old 10-26-2014, 11:01 AM   #4
Rewards Points: 1,832
Those look like Bulldog pushmatic. E-bay is one option if looking for used/original, Connecticut Electric UBI is another if looking for new replacements.
Jump-start is offline   Reply With Quote
Old 10-26-2014, 11:08 AM   #5
Here is UBI's sell sheet:
http://www.connecticut-electric.com/...ut%20Sheet.pdf
Home depot carries them online:
http://www.homedepot.com/b/Electrica...estoreoption=2
The Following User Says Thank You to Jump-start For This Useful Post:
lilabadge (10-26-2014)
Old 10-26-2014, 11:25 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
To bad I can't email you mine.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-26-2014, 01:23 PM   #7
Rewards Points: 6
Thank you, Jump Start
Jump Start, I did not see any photos of my breakers on the Con. Electric Site. or the Home Depot site. Thank you so much for the links!
Old 10-26-2014, 01:39 PM   #8
Oso954's Avatar
Rewards Points: 1,118
Should be able to get them thru one of your electric supply houses.
If not, Amazon has a complete line.
Here is a link to one of them.
http://www.amazon.com/Connecticut-El...rcuit+breakers
Edit: A lot of the Pushmatic panels are a split bus, so the upper breakers remain hot, unless you have a master disconnect somewhere else. The lower breaker positions are shut off by one of the upper breakers. Be sure the breaker position is dead by testing before attempting to unscrew the breaker.
If you are not sure about it, call an electrician.
Oso954 is online now   Reply With Quote
Old 10-26-2014, 04:22 PM   #9
PoleCat's Avatar
I hated that about mine. The 240V breakers are on the top bus and you have to work them hot or pull the meter.
Old 10-26-2014, 09:30 PM   #10
How many amps are you looking for? Single or double pole?
Keep in mind these breakers are no longer made, so the replacements will look different.
Look under "pushmatic":
http://www.connecticut-electric.com/...-pushmatic-reg
GE 2020CCU panel with 38 breakers! what to do. jandvs Electrical 11 07-05-2014 12:15 PM
GE Panel - Breakers - Tandem or Slim? TBrown1 Electrical 12 06-05-2012 07:42 PM
breakers compatible with panel--HD says... Daneel Electrical 6 06-10-2011 06:31 PM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
