Old Electric Panel/ Circuit Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 12:01 PM   #1
I have a home with a very old circuit breaker and when I have a lot of things running especially with a indoor electrical heater a breaker goes off. I want to buy another electrical heater and I found one with a backup thermal circuit breaker. Will this circuit breaker go off before the main circuit breaker goes off if there is to much power being drawn? I'm assuming that it won't.
Thanks,
dankreboot is offline   Reply With Quote
Old 12-16-2008, 12:29 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Thanks,
Are you tripping your main right now? Or are you just triping a 15 or 20a breaker for a branch circuit?
I doubt the new heater will solve your problem. It sounds like you are overloading a branch circuit. But I am confused by you mentioning your main breaker, please clarify.
Jamie
jamiedolan is offline   Reply With Quote
Old 12-16-2008, 12:31 PM   #3
Sorry for the confusion, I'm tripping a branch circuit.
Old 12-16-2008, 12:52 PM   #4
DIY'er
jamiedolan's Avatar
Then Option include:
Then either reducing the load on the circuit (run less on it).
Upgrading the circuit (assuming it is now a 15A, by running new wire 12gage and putting in a 20a breaker).
Add a new outlet or outlets on a new circuit.
Plug the heater in on a different circuit.
Run a smaller heater (with less wattage).
The heater is likely tripping due to the total load on the circuit (lights and other items + the heater), This is not something any heater can detect.
You really should find a solution to this, you do not want to keep overloading the breaker over and over again.
Jamie
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 03:06 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 04:01 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
