Old Delta Jointer Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:09 PM   #1
Rewards Points: 37
Question
I pulled the old switch out of this antique jointer because I wanted to move it to a more user friendly location, plus the wire connections didn't look great. When I opened it up I found a switch with 4 terminals, two on top, two on bottom. The bottom two are the line in, black and white wires, one each. On the top of the switch, above the black wire there is a red wire and a white wire going into the motor. Above the white wire, a white and black wire going into the motor. (the pictures will explain this best) Whats going on here? I have a new 20 amp single pole switch that I thought would work, now not so sure. Can I wire combine the white line in to the black and white into the motor, and then combine the black (switched) wire to the red and black going into the motor? When I got this thing it had a 120 volt plug on it, I plugged it in and it worked. Thanks.
RodBarney is offline   Reply With Quote
Old 12-21-2011, 09:33 PM   #2
Rewards Points: 6,652
Wouldn't that switch actually be a Double-Pole, Single Throw.
The Following User Says Thank You to gregzoll For This Useful Post:
RodBarney (12-21-2011)
Old 12-21-2011, 09:35 PM   #3
Missouri Bound's Avatar
Did the switch still work? If so, put a meter on it to determine which terminals switch what. Using that information you can decide your wiring diagram. I'll assume it's a 120v motor?...no?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 12-21-2011, 09:40 PM   #4
The pictures must have resized everything, didn't see all the information.
DPDT is the proper switch as gregzoll already mentioned.
Old 12-21-2011, 10:11 PM   #5
Missouri, A Double Throw would be two poles, On-Off-On, the Single throw would be two poles, On-Off. As for a good switch to use with safety cutoff, I am sure Graybar would have something, since what Radio Shack would have, may not be good enough, but Parts Express may have, with a kill cover that can be pushed down to kill the circuit, vs. just a paddle switch.
Old 12-21-2011, 10:17 PM   #6
Originally Posted by gregzoll View Post
Missouri, A Double Throw would be two poles, On-Off-On, the Single throw would be two poles, On-Off. As for a good switch to use with safety cutoff, I am sure Graybar would have something, since what Radio Shack would have, but Parts Express may have, with a kill cover that can be pushed down to kill the circuit, vs. just a paddle switch.
Yeah...you are right.....guess I'm having a brain fart night.
Old 12-21-2011, 10:21 PM   #7
Rewards Points: 506
So in the original switch is the neutral switched also? If yes, then a SPST could work by bypassing the switching of the neutral. Just connect the neutrals.
Edit: oops...looked again at picture. I don't think so.
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
Old 12-21-2011, 10:36 PM   #8
Rewards Points: 37
Thanks. So I need a Double-Pole, Single Throw correct? And that's the only switch that will work?
Old 12-21-2011, 10:39 PM   #9
Rewards Points: 37
I think that's kinda what I was getting at with my post. But it sounds like a no go from what I gather..
Old 12-21-2011, 10:41 PM   #10
Yes, if there are two hots. I would sit down with a pencil and paper, and draw out a wiring diagram, if there is not one available for that unit.
I was always amazed how neat my father's wiring diagrams were, due to he was a old school Radioman for the Air Force, and worked for the telephone company. It is a art that people forgot about, and tend to rely too much on technology to take the place.
Just remember, L1, L2, N, G. Colored pencils work really well for keeping it straight. As for the switch, you could use a SPST, if only 120. The reason to kill the neutral, is so that you know that the circuit is totally dead, and there is no way for a back feed to happen, when shutting down.
Old 12-21-2011, 10:44 PM   #11
Here is a listing of the heavy duty switches from partsexpress.com http://www.parts-express.com/wizards...TOKEN=71660348 They also have the Switch Cover, which would keep it from being powered, when the cover is down. The hard part will be finding anything larger than 20a/120vac through them. Here is a 40a at Graybar https://shop.graybar.com/webapp/wcs/...es=&formTypes= oggle Switch, Contact AC Voltage 600V, Contact AC Current 40 Ampere, Power Rating 5 Hp at 250V AC, Contact Configuration Dpst, Silver Cadmium Oxide Contacts, Terminal Type Screw, Operating Temperature -40 to 65 Deg C, Size 1.2 Inch x 1.87 Inch, Used For Welding, UL
They also have 30 amp rated switches, that would work if the motor is no more than 2hp.
Old 12-21-2011, 10:57 PM   #12
Rewards Points: 37
Thanks Greg for the help. I am certain that this thing is wired for 120 volts. Well I guess I shouldn't say certain, but there was a 120v plug on the end of the cord and I plugged it in (reluctantly because the cord was frayed to the copper in about ten places) and it fired up and ran. So I am confused why there would be two hots, in my limited experience I thought that was for 220. Uh for a wiring diagram, I have done a few with success, but this is a whole different animal for me. I know I have three wires coming out of the wall and I know where those go, why there is two whites, and a red and a black going into the motor..well I haven't wrapped my brain around that yet.
Old 12-21-2011, 11:25 PM   #13
Rewards Points: 37
Thanks for the links, I'll check it out.
Old 12-22-2011, 08:52 AM   #14
I=E/R
a7ecorsair's Avatar
FYI - I'd bet that the motor can be wired 120 or 240 so the switch would have to be two pole which can support either configuration.
To use a single pole switch connect together all the wires on the side of the switch that your white power neutral. Connect your power hot to one side of the switch and all the wires on the hot side to the other screw on the switch.
a7ecorsair is offline   Reply With Quote
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
