Old Cutler Hammer CH12 Panel - Ground Block - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 10:47 PM   #1
Rewards Points: 12
Post
Old Cutler Hammer CH12 panel - ground block
Have an old Cutler Hammer CH12 panel being used as a sub panel right next to our existing main panel in a home we just bought. Installation date on the sub panel says from 1970. Whomever installed it did not isolate the neutral wire. They only have 3 wires going to the sub panel. Probably because none of the existing outlets have a ground pin. I have been rewiring the whole house little by little replacing all the 2 wire romex with 3 wire armoured cable as well as replacing the outlets with the correct 3 wire ones. I want to fix this sub panel issue by adding the appropriate ground wire. I noticed the newer Cutler Hammer panels have studs on them to add a ground block if one is not already on the panel. This panel does not. Can I just add a ground block and fasten it to the panel? I am thinking not, but thought I would ask.
GroundLoop is offline   Reply With Quote
Old 02-14-2012, 10:59 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You can buy ground blocks sometimes you can get them for a specific panel. And sometimes you have to just buy one and use self tapping screws to mount them inside the panel.
rrolleston is offline   Reply With Quote
Old 02-14-2012, 10:59 PM   #3
Julius793's Avatar
Yes you can buy a CH ground bar and attach it. Use the wholes provided in the panel and do not use sheet metal screws
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-14-2012, 11:00 PM   #4
Julius793's Avatar
Self tapping sheet metal is a code violation!!!
Old 02-14-2012, 11:15 PM   #5
rrolleston's Avatar
The holes are usually not threaded and when you put the screw in it threads the hole.
Old 02-14-2012, 11:21 PM   #6
Rewards Points: 12
Thats the problem though... I do not see any holes that look like they are for attaching a ground block. The only holes on the panel are the 4 mounting holes - one in each corner.
Old 02-15-2012, 12:33 AM   #7
Julius793's Avatar
That exactly why the nec says you cannot use it!!! Article 250.8
Old 02-15-2012, 01:29 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Actually there is the other way you can get around is use the self tapping machine screw they are more finer on thread pitch and per NEC code you need minium of two thread engaged in the metal.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
zappa (02-15-2012)
Old 02-15-2012, 04:23 AM   #9
rrolleston's Avatar
Merci,
Marc
That is what I use I don't use those drill and tap screws.
The same ones that come with the panel. Sometimes I have to flip the guts of a panel around and when I do the screws just thread into the pre drilled holes.
I also have small machine screw taps that work very nice.
The Following User Says Thank You to rrolleston For This Useful Post:
frenchelectrican (02-15-2012)
Old 02-15-2012, 08:19 AM   #10
Rewards Points: 12
Can I just drill my own holes in the panel and attach the ground block? Maybe put nuts behind the panel on the bolts?
Old 02-15-2012, 08:41 AM   #11
rrolleston's Avatar
Not sure if this is legal. I think they use 10-32 machine screws. I have some that drill and tap a hole and then I replace with short standard machine screws.
Old 02-15-2012, 10:19 AM   #12
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Don't mess with drilling holes in that panel. Many panels of that era did not provide provision for adding grounding bars. You certainly can use machine screws as Frenchy mentioned.
I would replace it... but not because its old or unsafe.
Panels of that size are cheap and breakers are cheap. BTW you do not need a main breaker in the new sub. Look for a value pack at a big box .. panel plus breakers.
You can consider using metal conduit (emt or rigid) between the service panel and new sub-panel instead of an equipment grounding wire ran with the feeder conductors.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
sub panel ground katahdin Electrical 4 04-21-2011 11:13 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
