Old Chandelier Mount - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 11:22 AM   #1
Old Chandelier mount
I need advise or suggestions on how I can hang this new chandelier with the least amount of work/headache. When I pulled off the old light this is what I found (see link). I don't know what that mount is or how to remove it or if I should remove it but I can't mount the new light to it because as you can see the wiring does not run through the middle of it as it would have to in the new light. The original ceiling is plaster and it looks like another drywall ceiling was installed directly underneath with a small gap. I really don't want to cut into the old celing if I can avoid it.
Thanks in advance!!!
<a href="http://s1334.photobucket.com/user/Mc...e23ac.jpg.html" target="_blank"><img src="http://i1334.photobucket.com/albums/...ps3e5e23ac.jpg" border="0" alt=" photo electrical_zps3e5e23ac.jpg"/></a>
McQue is offline   Reply With Quote
Old 05-13-2013, 02:07 PM   #2
JW
mm11's Avatar
Rewards Points: 596
It looks like you need a 1/2" chase nipple
and a fixture hickey.
Screw the close nipple into the threads in the box and attach the hickey. The chandelier should thread onto the hickey, and the fixture wires enter the box through the opening of the hickey.
Google 'fixture hickey' and go to images for more diagrams and info if needed.
mm11 is offline   Reply With Quote
Old 05-13-2013, 02:40 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,640
Geeze MM... what a great response.... by the way I googled "hickey" and found some interesting sites.... but not the part you describe
MTN REMODEL LLC is offline   Reply With Quote
Old 05-13-2013, 05:06 PM   #4
JW
mm11's Avatar
Rewards Points: 596
You must have forgot the word fixture
Old 05-13-2013, 11:12 PM   #5
MM. Thanks for the response and diagrams. More than I could ask for. I'll head over to lowes when I get a chance and pick those two items up and give it whirl. I'll let u know how it goes. Thanks again!!
Old 05-14-2013, 06:13 AM   #6
Rewards Points: 734
Good luck buying a Hickey today. I haven't seen one for sale in years. Electricians usually have a scavenged supply.
Mark
busman is online now   Reply With Quote
Old 05-14-2013, 08:50 AM   #7
JW
mm11's Avatar
Rewards Points: 596
The only time I go to Lowe's is if my wife wants window treatments and the like.
Lowe's electrical department is subpar, and filled with chinese junk. They do have good customer service however.
Home Depot has a far better selection in their electrical department, and has much more available made in US (or at least North America).
IMO, Home Depot is geared to the contractor while Lowe's is focused on the homeowner.
Neither store carries fixture hickeys AFAIK.
You'll probably have to either go to a electrical supply house or look online.
Here's a link to an entire kit- looks like it probably has everything you'll need.
http://www.antiquelampsupply.com/pro...FcXe4AodFSsATg
DIY Camera Mount divedaddy03 Tools 0 04-06-2013 02:05 PM
Fuse for chandelier with 12-volt transformer? S_Jeff Electrical 1 08-16-2012 12:19 AM
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 02-01-2012 12:34 AM
Mounting huge TV+sound bar above TV with down&out mount djgrant Building & Construction 6 10-05-2011 02:55 AM
Grounding a Hanging chandelier made for a electrical box Mount mjgumbo Electrical 6 03-21-2010 08:01 PM
