Old Ceiling Light Wiring Help!! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 05:03 PM   #1
Old ceiling light wiring help!!
I'm working on replacing an old (1960's) ceiling light with a fan and I having a wiring question.
The box has two black wires wrapped together, two white wires wrapped together and a yellow wire alone. After using a "live wire" to determine which was hot, they all beeped. Some more furiously than others, but all nevertheless.
So which is which?
Budl09 is offline   Reply With Quote
Old 08-28-2011, 05:25 PM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
Black should be hot, yellow is probably part of a 3-way switch.
picflight is offline   Reply With Quote
Old 08-28-2011, 05:31 PM   #3
analogmusicman's Avatar
Rewards Points: 560
I guess there was a fixture in there before. so how was it wired?
analogmusicman is offline   Reply With Quote
Old 08-28-2011, 05:31 PM   #4
Licensed electrician
Rewards Points: 1,234
You have a couple of issues; the wires should be in a cable or conduit, not individual conductors run into the box. Two the gap around the box needs to be repaired so it is no greater than 1/8". Three the box does not look to be rated for fan support and should be replaced.
Old 08-28-2011, 05:43 PM   #5
The old light had the two black wires taped together and attached to nothing. The gold wire and the white wire were attached to the light. I just can't remember in what order.
The wires running into the box are in conduit but the conduit couldn't reach the new box. The box is rated for a fan as it came with one of those extension rod kits. The hole around the box is going to be filled as soon as I know I don't have to make any more changes. That way I won't have to cut it out again.
Old 08-28-2011, 06:06 PM   #6
Rewards Points: 560
any color wire except white and green can be a hot wire so I guess your yellow wire is hot and those white wires are neutral. so the whites would go to your fan's white and your yellow to the fan's black. the fan's ground (maybe green?) would go right to that box as long as it's a grounded box.
personally,I use a cheap "radio shack" vom (meter) to check voltage on wires to be sure.
Old 08-28-2011, 08:03 PM   #7
Thanks!
Old 08-28-2011, 09:06 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
First step is to get the conduit to the box. As Jim mentioned, you can’t have individual wires run to the box like that. If you don’t have a green or bare wire in the conduit going to the box, then the conduit would be the ground. Without the conduit attached to the box, it won’t be grounded.
Kyle
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 03:29 PM
how to turn ceiling light into a fan w/ ceiling light MLMIB Electrical 4 06-06-2011 09:04 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
wiring ceiling fan to light switch cshsr Electrical 10 07-20-2009 05:08 PM
