Old Bx Cable - Romex, Tv Humming - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 07:43 PM   #1
Question
Old bx cable - Romex, tv humming
I just replaced a section of old bx cable from the electric panel into a plug box in the living room, I am remodeling a room and had access to the open wall. the walls are closed in the living room and can't replace the bx to the end of the line. I used 12/2 romex wire, grounded it to the box and the plug. The bx is grounded through the connection to the box. Since I replaced the wire, I am getting a slight hum and slow horizontal line on the TV in the living room. Does anyone have any idea what might be cause it??
Ensueno76 is offline   Reply With Quote
Old 11-06-2011, 09:38 PM   #2
Rewards Points: 6,652
Check the grounding on the coax first. Also, are you talking antenna for the tv signal, satellite, Verizon Fios, ATT U-Verse, CATV provider? Second would be improper ground. Is the panel in the home still a fuse panel, or is it a breaker panel. Really need you to place location in your profile, or just state, along with the age of the home.
If the coax was properly installed to the home by your catv provider, and that the electrical system, regardless if it is older armored or newer romex, if it was properly installed, you should not have a ground loop problem, which it sounds like.
Old 11-07-2011, 09:17 AM   #3
The home was build in1949 it has a square d panel with breakers its in new york and the tv signal comes from cablevision
Old 11-07-2011, 09:47 AM   #4
I would be checking for proper ground bonding, and that the catv is properly grounded at the ground block. If still getting humming, then there is that possibility, that you have voltage on the line causing the problem, and would have to measure on the coax for it.
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Cut resistance of Romex cable? Ultrarunner2017 Electrical 3 10-25-2008 02:37 PM
Allowed to run more than one romex cable through a single hole in a joist? J187 Electrical 7 08-17-2007 08:46 AM
