Old 12-10-2010, 04:06 PM   #1
Old Amp Trap
I have an old Amp Trap fuse. It is about 8 inches long in total, with a cylindrical body and two opposing, silver-looking blades. I would guess it is at least 30 years old.
Were the blades ever made of solid silver, not silver-plated as I see described on the Ferraz Shawmut web page?
http://us.ferrazshawmut.com/catalog/.../european-iec/
Thanks!
cgoll is offline   Reply With Quote
Old 12-10-2010, 08:43 PM   #2
joed's Avatar
Old Amp Trap
I have never seen a fuse with silver blades. They are almost always copper and tin plated.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-10-2010, 09:22 PM   #3
Old Amp Trap
Actually, if you read the description of the fuse at the very bottom of the link, it says they are silver plated.
I took an Exacto to mine and there is a copper core, but the silver plate is pretty thick.
Old 12-10-2010, 10:05 PM   #4
Old Amp Trap
I took some pictures. It is certainly not pure silver, but it is still interesting. I also took a bolt cutter to it to be sure...
I sanded the tarnish off the right side so that is why they look different.
Old Amp Trap-104_0623.jpg   Old Amp Trap-104_0624.jpg   Old Amp Trap-104_0625.jpg
Old 12-10-2010, 10:49 PM   #5
nap
You talking to me?
nap's Avatar
Old Amp Trap
I can't read the part number on the fuse you have but do you realize the link you provided is about IEC (European) rated fuses? I don't know if anything on the EIC page would be applicable to your fuse.
Old 12-10-2010, 11:26 PM   #6
joed's Avatar
Old Amp Trap
Tin plated copper, like I said.
Old 12-11-2010, 03:09 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Old Amp Trap
That look like 200 amp 240 volt fuse but few case it may be 100 amp 480 volt fuse can you post the number we can able translated it clear.
Merci,
Marc
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 04:18 AM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 01:40 PM
Cat trap fever radtek General Discussion 13 05-31-2009 07:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
