Old 11-09-2012, 06:04 PM   #1
is it okay to plug a ups into a gfi outlet?
is it okay to plug a ups into a gfi outlet? I will be using my pellet stove on the ups so the fan runs in case of a power outage.
rhinewilliam is offline   Reply With Quote
Old 11-09-2012, 06:08 PM   #2
JOATMON
ddawg16's Avatar
Sure....as long as the UPS current input is less than the rating of the GFI.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-09-2012, 06:36 PM   #3
If the GFCI protection is not needed or required, you are OK.
But, a UPS does not normally have any GFCI protection on the down stream side, so you are defeating the protection that would otherwise be provided by the GFCI outlet.
Oso954 is offline   Reply With Quote
Old 11-09-2012, 06:54 PM   #4
Wink
Understood, the GFCI outlet is already there and the pellet stove is plugged into it, I was just trying to make sure I wasn't going to run into any problems and to save myself having to put in a normal outlet. Thanks guys!
250V 30amp 3 post plug on a bandsaw, change the plug to a 4 post plug question benjeremiah Electrical 3 10-04-2012 12:43 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 11:11 PM
