Is It Ok To Vent An Electric Dryer Through A Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 06:49 PM   #1
Is it ok to vent an electric dryer through a wall?
I will be building a new 2 x 6 wall and I want to run the dryer vent to the outside down the length of the wall, approximately 10'. Acknowledging vent length limitations including restrictions (45 and 90 degree turns), the requirement of 4" galvanized pipe, avoiding screws (is aluminum tape ok?), the need to clean the vent every 3 or 4 years, and other obvioius requirements, would this vent meet code requirements?
kebmeister is offline   Reply With Quote
Old 09-23-2012, 07:01 PM   #2
Missouri Bound's Avatar
It's done all the time. Do you mean aluminum vent?
Do you want it your way or the right way?
Old 09-25-2012, 02:53 AM   #3
new guy
If you'll be drying loads for an average family of 4, you should probably run the lint out every year, esp. since your duct will have some turns in it. You may have condensation forming in it particularly toward the end where it is cooler, so it would be good to position the run so that any condensation will drip out rather than pooling inside the duct.
Avoid using the fabric softener sheets. That stuff makes hard to remove lint residue in the ducts and at the cap.
Check to see if double-walled ducting is required for sections in the wall.
Brian
bclee is offline   Reply With Quote
How to vent dryer when rim joist is close to ground LucknowPaul Appliances 6 08-07-2012 07:24 AM
Problem with in wall dryer duct. darsunt HVAC 5 02-02-2012 12:23 PM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Dryer vent butterfly damper safe? TryHard Appliances 9 01-17-2011 02:44 AM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 12:02 AM
