Old 03-30-2009, 12:53 PM   #1
Ok to use outdoor enclosure in garage?
Ok, this is probably a ridiculous question, but just wanted to make sure before I bought anything. Is it ok to use an outdoor enclosure indoors? I'm going to pick up a small panel for the sub-panel project for my garage, but most of the smaller indoor panels seem to not have a door to protect the breakers. I'm just looking for something to keep curious little hands away and protect the breakers from the occasional basketball that might bounce its way.
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 03-30-2009, 01:00 PM   #2
dSilanskas's Avatar
Yes you can your fine
dSilanskas is offline   Reply With Quote
Old 03-30-2009, 01:36 PM   #3
Remodeling Contractor
There are indoor and exterior panels. there are surface mount and recessed mount panels. You can use an exterior panel inside or outside. You cannot use a recessed panel for a surfaced mount application.
Old 03-30-2009, 01:57 PM   #4
Send a message via AIM to theatretch85
I would suggest just installing a 100 amp 20 space panel. This is a common main breaker panel with or without the main breaker installed (if the garage is detached you must have a disconnect at the sub panel). This type of panel has the standard door on the panel, and gives you plenty of room to work with and space for extra circuits down the road. Also, this panel can be installed in the wall verses needing to be installed on the surface of the wall.
theatretch85 is offline   Reply With Quote
Old 03-30-2009, 04:12 PM   #5
47_47's Avatar
I agree with the 100 amp panel. Get one that uses the same breakers as your main panel.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Garage Door Install marly General Discussion 2 11-17-2008 03:51 PM
