OK - So I'm Alone Here On Christmas And I'm Using My Toner - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2012, 06:55 AM   #1
Rewards Points: 372
Question
OK - so I'm alone here on Christmas and I'm using my toner
I'm diagnosing an open fault on an overhead radiant heat system. 240V, 20A circuit, SPST thermostat. I've already opened up a small hole and have full access to the overhead system.
I'm getting an infinity reading on ohms, but I located a break with my toner and repaired it, and STILL no connectivity.
I'm using my toner, and I can tell there is some kind of connection between the t-stat drop and where I found the break (loud LOUD tone, same as if I touch the toner to the other end of the wire), but when I use my long lead to test DVOM continuity at that point I'm still getting infinity.
So - with the wire exposed I get 100% tone continuity to this spot, but when I use my ohmmeter I still show infinite. Frustrating.
Help!
imautoparts is offline   Reply With Quote
Old 12-25-2012, 07:10 AM   #2
Items wanted: Time
Rewards Points: 150
Will the unit run if the thermostat is jumped out at the unit itself? If so replace all the tstat wire since you already found one break.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
imautoparts (12-25-2012)
Old 12-25-2012, 07:50 AM   #3
Rewards Points: 372
No, I'm just not getting continuity. The t-stat is working fine. I think I may have isolated another break point near the wall-"up" line on side b
My plan is to slowly identify any breaks using side A, till I get right near the t-stat. I'll post back after fixing this break #2
Old 12-25-2012, 11:50 AM   #4
Rewards Points: 372
Done and done. I'm sure I wasn't the most efficient finder of broken spots, but after three cuts into the ceiling I got a good solid tone from the whole grid.
Checked continuity - 70 ohms of resistance, plugged in the breaker, drawing 7 amps from dead cold. Good deal - and thanks to DIY Chatroom!
Drinks for everyone!!
How to hang Christmas tree from the ceiling jwu11 Interior Decorating 5 11-26-2011 01:04 PM
Christmas Display - Ongoing but here's a Start Scuba_Dave Off Topic 211 08-22-2010 08:54 AM
Last Minute Christmas Gift Suggestions user1007 Off Topic 0 12-24-2009 08:11 AM
Looks like a good Christmas this year! leroyme Off Topic 6 12-23-2007 10:45 AM
