OK To Run T-stat Wiring In Same Chase As Heating Pipes? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 03:57 PM   #1
OK to run t-stat wiring in same chase as heating pipes?
i used an old heating duct to run a supply/return of 3/4" copper for a baseboard.
it would be super convenient to drop my thermostat wiring right down this same duct to the basement. would it melt?
thanks.
wombosi is offline   Reply With Quote
Old 09-11-2009, 05:47 PM   #2
Electrical Contractor
kbsparky's Avatar
Not likely. The wire has to get much hotter than the boiling point of water to melt.
You should be fine fishing that wire through the same chase.
-KB
Old 09-11-2009, 05:52 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
What’s the max temp the pipes would ever be? What’s the max temp rating of the stat wire? Would it? Probably not. Could it? Sure…anything is possible.
Kyle
Old 09-11-2009, 06:15 PM   #4
old as no longer in use?
Since you now have hot water baseboard I doubt it would get hot enough
Try to string it a couple inches away from the hot water going to the baseboard. The return copper line will be cooler
Old 09-11-2009, 07:40 PM   #5
thanks a lot guys. this is good news.
scuba: yes, the duct is no longer in use as a heating duct. the house used to have a coal furnace.
Draining heating pipes to do work on walls RyanD Plumbing 5 06-15-2009 02:06 PM
Why do i hear the water in my heating pipes? CMG Plumbing 3 12-09-2008 11:33 AM
I hear the water running in my heating pipes CMG HVAC 3 12-08-2008 06:46 PM
Hot Water Heating, burst/frozen pipes, use pex etc??? diyjohn HVAC 3 11-14-2008 04:07 PM
air in baseboard heating pipes dangerouswithtools HVAC 7 02-24-2008 06:26 PM
