Is It OK To Run Hotwire Through Single Pole Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 10:30 AM   #1
Is it OK to run hotwire through single pole switch?
I am adding a light to a pole. Because of where the switch is and some wires that are already in place it would be most simple to run the hot wire through the single pole switch rather than the common. I am no expert but from reading I see that generally the common is routed through the switch. I seem to recall from my high-school electricity/electronics class that either the hot wire or the common can be routed through the switch since all it does is complete the circuit when it is closed? Is this correct? I hope so because it will make my wiring much more simple. Thanks very much for any input!! It's at my home, 120 service, of course I am also running a ground wire.
TFastle is offline   Reply With Quote
Old 11-11-2010, 10:38 AM   #2
Licensed Pro
ONLY the hot wire should be connected to a switch, never (in a dwelling) the neutral.
Old 11-11-2010, 11:16 AM   #3
Thanks House Helper. I assume it does not matter which side of the switch the light is on or the supply? Also, on the switch I have, one side of it is labeled "common", why is that or what is meant by that? Sorry to be so dumb about this. I did pull the plate and look a similar set up and indeed the single pole switch only had a hot in and a hot out and a ground. Thanks again!
Old 11-11-2010, 11:23 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
If you have a switch with a common screw, then you have a 3 way switch.
You can use this as a single pole switch, but you have a 50/50 chance of having an upside down switch.
jbfan is online now   Reply With Quote
Old 11-11-2010, 11:26 AM   #5
ahhh... that makes sense. Okay, I am good to go. Sure appreciate the help JBFan and Househelper! Time to get to work. Thanks again!
Tags
common wire , hot wire , switch
3 wire romex for single switch jraf Electrical 4 04-06-2010 08:46 PM
GFCI on generator tripping; home backup MrNeutron Electrical 21 07-02-2009 10:11 PM
GFCI & Single Pole Switch combo II Weeks Electrical 12 04-10-2009 05:57 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Help with single pole switch ballutster Electrical 2 10-13-2008 07:57 PM
