Is It OK To Power A 220v Tankless With Only 120v? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 11-10-2012, 07:03 AM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by wonderworm View Post
I find it interesting that I get attacked but noone seems to have an answer to the single question I asked.
I find it interesting, even funny, that some folks consider not getting the exact answer they WANT on a message board as being "attacked".
Will an entry level 240v tankless at 120volts produce roughly the same heat as a 120v tankless at 120volts? I think I'm just too outside the box for some here.
My answer would be a firm NO.
Pretty much every insta-hot water heater I have seen has had electronics and circuit boards. My guess is that they are designed to run at the voltage spec'd on the unit. Supply it with half that voltage and you let all the magic smoke out of the electronic components.
Standard storage type old-school water heaters do not have these electronics. Just mechanical thermostats and heating elements.
Speedy Petey is offline
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
Bobka (11-13-2012), k_buz (11-10-2012), mpoulton (11-10-2012), TTW (12-18-2012)
Old 11-10-2012, 08:15 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Add to that the fact that if the unit is spec'd to run at 240V, you don't have an option to run it at 120V.
k_buz is offline
Old 11-10-2012, 08:39 AM   #18
But what if he reeeeeaaallly wants to??
Old 11-10-2012, 08:46 AM   #19
k_buz's Avatar
I completely forgot about the "REALLY wants to exception".
k_buz is offline
The Following User Says Thank You to k_buz For This Useful Post:
Jim Port (11-13-2012)
Old 11-13-2012, 01:51 PM   #20
Originally Posted by AllanJ View Post
Why not convert the line that is going to feed the tankless heater into a 240 volt line?
Install a double wide 240 volt double breaker for it, remove the neutral from the neutral bus at the panel, and connect that white wire to the other half of the double breaker. Disconnect all other receptacles, lights, etc. from the line, wire nutting the wire ends inside each box daisy chained along the way as a pass through only. (The tankless draws enough amps that the circuit should be dedicated to it.)
Now this is the type of outside the box solutions I'm talking about. I think your idea will work Allan. I spec'd a Chronomite 240v 7.2Kw tankless that will run on 30 AMPs. My existing wire is a dedicated 10-2 wire which can support 30AMPS of draw! Seems a perfect fit. Much better than the strongest 120v which only puts out 3.6Kw.
wonderworm is offline
Old 11-13-2012, 02:05 PM   #21
Rewards Points: 332
I mentioned this in post #2 but you said you couldn't do that.
sgip2000 is offline
The Following 2 Users Say Thank You to sgip2000 For This Useful Post:
mpoulton (11-13-2012), Speedy Petey (11-13-2012)
Old 11-13-2012, 02:14 PM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Yep....you sure did.....
If possible, why not just wire it for 240V? A tankless running at less than full power will not heat very well.
and he sure did.....
Unfortunately, it's not possible. My options are to buy a 220v wired as a 120v or 120v wired as a 120v. Do you think the 220v at 120v power will heat equally as poorly as the 120v tankless?
ddawg16 is online now
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 11-13-2012, 05:15 PM   #23
Sorry, from the phrasing of your brief comment it indicated like you were advising to run new thicker 240v wire to the location and why I said it was not possible. I'll update once I get it installed and tested.
Old 11-13-2012, 05:26 PM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Not what I would call "out of the box" thinking, but the most common way to wire a 240 only device.
Coastal South Carolina
rjniles is online now
The Following User Says Thank You to rjniles For This Useful Post:
Old 11-14-2012, 09:25 AM   #25
Semi-Pro Electro-Geek
Rewards Points: 2,938
There is no "240V wire". Almost all wire you can buy is 600V rated, and the rest of it is 300V rated. The thickness is pretty much the same. Wire is wire. What you connect it to matters.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline
Old 11-14-2012, 09:30 AM   #26
Rewards Points: 150
To expand on that slightly.
The insulation (type and thickness) is the primary determinant of the voltage rating. The wire size and material determines the current capability.
Dave632 is offline
The Following User Says Thank You to Dave632 For This Useful Post:
TTW (12-17-2012)
Old 12-14-2012, 03:15 PM   #27
For the 240v unit, it may use the same wiring as the 120v model, if it is straight 240v and not 120/240v.
Do you have space in your panel for a double pole breaker?
Here's the update after completing this install for anyone looking to do a similar job.
I removed an old leaking 20gal water heater that was in a utility closet that supplied a clothes washer, dishwasher and kitchen sink and replaced it with a 240v 7.2Kw tankless.
My copper pipe run was longer than recommended, 30'+ feet and because of that, during winter it takes a good 45 seconds for the pipe to warm up so expect similar if you also have a long pipe run. The water, (atleast during winter) only gets hottub hot but that is acceptable for me. I used the existing #10 wire and simple moved the white neutral wire to the second pole on a double pole breaker to convert the wiring to carry 240v. And painted the white wire red to designate that that wiring was now 240v or "hot". I got rid of the now unneeded TPR valve and used standard 1/2'' to 1/2'' stop valves off the wall and standard 1/2'' to 1/2'' flexible toilet connections so the install was cheap and easy.
The result is I now have a good looking clean closet install on the wall with tons of new storage, my electric bill is already dropping and I never have to worry about a cracked leaking tank flooding my house ever again. Thanks to sgip2000 and allanj for the idea.
Old 12-14-2012, 03:43 PM   #28
A "Handy Husband"
rjniles's Avatar
What size (amp)2 pole breaker did you use? According to the manufacture, you need a minimum 40 amp breaker with #8 wire for this heater.
Removing a unneeded TPR valve says "Danger- Will Robinson"
Old 12-14-2012, 08:37 PM   #29
repost.
Old 12-14-2012, 08:47 PM   #30
Originally Posted by rjniles View Post
What size (amp)2 pole breaker did you use? According to the manufacture, you need a minimum 40 amp breaker with #8 wire for this heater.Removing a unneeded TPR valve says "Danger- Will Robinson"
The chronomite that puts out 7.2Kw requires 30amps with 10 guage wire. I have the 40 amp handy but so far I have been able to run it on the 30amp double pole without it tripping the breaker once and 10 gauge wire is rated for 30amps. Checked the wire after 10 minutes of continuous operation and it was not hot.
"Tankless" has no "tank" thus no pressure build up so TPR valves are not required but you already know that, right?
But don't take my word for it, ask a manufacturer. "Installation of our tankless water heater is quick and easy. Under normal conditions, it requires no pressure relief valve. "
Closed Thread
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
need power for 120v to 12v undercabinet lights robin hood Electrical 2 02-26-2008 03:43 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
