Ok? - More Than 1 Line Per Switch Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 05:52 PM   #1
ok? - more than 1 line per switch box?
I am doing a bathroom, I have 3 separate circuits, can I put all the switches into 1 box? 2 - single poles, 1 - (two function control - 2 switches)
I live in new jersey if that matters.
1 circuit for 2 recessed lights
1 circuit for 1 UL damp recessed light with glass cover
1 circuit for Nu-tone exhaust fan/heater (this will have the two function control)
Thanks!
navy721 is offline   Reply With Quote
Old 06-18-2011, 06:04 PM   #2
Rewards Points: 1,654
Yes, get a 3-gang box:
Old work:
New work:
bob22 is online now   Reply With Quote
Old 06-18-2011, 06:07 PM   #3
THANKS!
Where can I find that this okay per state code? I am doing a favor for my buddy, and he says its not legal... driving me crazy. I've looked over the code but can find anything specific -
Old 06-18-2011, 07:10 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
Are you saying you ran TWO circuits for just this?? WHY????
If your friend thinks it is SO illegal tell HIM to prove it.
Old 06-18-2011, 08:04 PM   #5
Rewards Points: 1,536
You may run two (or more) feed cables to the same (multi-gang) switch box but make sure that the neutral for each light or other load goes with the hot wire feeding that load. Do not combine the neutrals of both feeds (same or different circuits). So you will have two (or more) bundles of wire nutted white wires.
Do combine all the ground wires. If the grounds don't all fit in one wire nut, have a jumper (pigtail) connecting the two ground wire nuts.
Old 06-18-2011, 08:09 PM   #6
Master Electrician
Rewards Points: 3,918
Are you talking about individual circuit feeds or several switch legs from the same feed. The loads you are describing certainly would not require several inndividual circuit feeds but that would be okay.
brric is online now   Reply With Quote
Old 06-18-2011, 11:38 PM   #7
Rewards Points: 6,652
When we redid our bath, we had a situation, that we thought of running the same circuit for the fan as the outlets, but then re-decided to rethink the lay out to make it easy. In your situation, do the same as us. One 20 amp for the outlets, and a 15 amp for the exhaust & lighting. For the lightening, my wife wanted one switch for the fan, one for the light in the fan, and one switch for the light over the mirror that was over the sink. If it was up to me, I would have one switch to control all lights in the bath, and use a triple-gang with blank to have only two switches. One for the lights, and one that did the fan. This is on my list of things to change, since it drives me nuts a year and a half later.
Old 06-18-2011, 11:49 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Thanks!
Naw you don't really need that MANY circuits at all the exhaust/heater unit it will be it own circuit but for the luminaires { light fixures } you can use them on genral lighting circuit.
That way you will not get this box overcrowed and get confused with which is which.
Few of us done more crazier than that. { commercal electrical system is different story but same situation }
Merci,
Marc
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
