Is It Ok To Install A Light Near A Drain Pipe? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 11:17 AM   #1
Is it ok to install a light near a drain pipe?
Can I install this light near the drain pipe? When the sheetrock goes up a vanity light will go where this temporary fixture is installed. Other details:there is no shower, the light and fan are not on a gfci. The one receptacle in this bathroom is a gfci.
toobhed is offline   Reply With Quote
Old 09-18-2011, 11:21 AM   #2
Licensed electrician
Rewards Points: 996
You have no code issues. Be sure not to try to anchor the fixture to the drain line.
Old 09-18-2011, 11:22 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
No problem with the light and drain pipe. Good point Jim.
Kyle
Old 09-18-2011, 11:32 AM   #4
Thanks guys!
Old 09-18-2011, 11:40 AM   #5
Rewards Points: 150
I inspired Toobheds question from another thread. Around here, that's a code violation. If there is any kind of failure with the sewer pipe, water will be on that light fixture behind the drywall. They call it a recognized hazard here. Electrical is not my thing and I would have thought the locals were calling out something in NEC or the like. I guess it's just a local thing.
TrapperL is offline   Reply With Quote
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 12:13 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
Tub Drain Install - What's The Trick? Ricky D Plumbing 2 06-09-2007 07:22 AM
