Ok To Have 2 GFI 's Sideby Side In Kitchen? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 09:38 AM   #1
Ok to have 2 GFI 's sideby side in kitchen?
I removed a wall switch in the kitchen that use to control the disposal. It was in a double box next to a seperately wired GFI outlet. Is it acceptable to put another GFI in place of the old switch? The new GFI would get power from a nearby regular wall outlet. Or should the new GFI be powered right from the panel?
Maine1 is offline   Reply With Quote
Old 02-20-2013, 09:52 AM   #2
sorry, I just realized I had this wrong...
Power comes from panel to (old) switch. From switch to another outlet below the sink (for disposal).
I removed the old switch and connected wires together so outlet below sink is always hot. (will be using air sink switch for disposal).
So now I have a double box above the countertop that currently has one GFI outlet (powered from a different circuit). Can I put another GFI next to it? And how should I power it up?
I hope this makes more sense...
If I cant add another GFI I can always just cover the open side of the box (we havent installed the backsplash yet) Not sure abuot the best way to cover it up though.
Old 02-20-2013, 10:19 AM   #3
jproffer's Avatar
Rewards Points: 716
There's no need to put another GFI on the same circuit. You can add a regular receptacle from the load side of the current GFI. There are usually stickers across those terminals...but maybe not. At any rate it will say LOAD next to them.
Using that side (LOAD side) will protect the regular receptacle just like it was a GFI.
jproffer is offline   Reply With Quote
Old 02-20-2013, 10:23 AM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
If you don't need more outlets, the simplest/cheapest thing would be to put a decora blank over it and call it a day.
hyunelan2 is offline   Reply With Quote
Old 02-20-2013, 11:17 AM   #5
Thanks for the help. I will just add the regular outlet off of the load side of the existing GFI as suggested. Probaby dont need that many outlets but the space is there, i might as well put one there.
One plug doesn't work in a two plug outlet. And this is happening in four outlets which are all in a row. They are all in our kitchen. One on each side of the stove, one behind the refrigerator, and the last is the one we are running our air condit chuckb Electrical 1 08-07-2012 03:26 PM
Kitchen question laur15 General DIY Discussions 3 11-24-2009 12:30 PM
kitchen on two levels...will this work? silkyblue4 Kitchen & Bath Remodeling 9 06-16-2009 09:18 PM
Kitchen sink side sprayer hose. rfjm58 Plumbing 2 03-24-2008 08:32 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
