Is It OK To Have 12-2 Romex In 1/2" Outdoor Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2009, 08:58 AM   #1
is it OK to have 12-2 romex in 1/2" outdoor conduit
I'm planning on installing an outdoor hot tub and want to make sure my plan is correct. The hot tub requires a single 120V 20A circuit. The hot tub itself has a GFI built into the plug, and I plan on driving an 8-ft grounding rod next to the hot tub.
I plan on running 12-2 w/ground from my service panel all the way to the hot tub and terminating the 12-2 with a plug that will match up with the one on the tub. The section of wire that is outside will be encased in 1/2" outdoor flexible waterproof conduit. Will this be OK?
red86yota is offline   Reply With Quote
Old 01-15-2009, 09:16 AM   #2
No. It will not. There are many problems with your plan. Are you sure the tub only requires 120V? Is this one of those inflatable ones?
jerryh3 is offline   Reply With Quote
Old 01-15-2009, 09:22 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Too numerous to mention.
wirenut1110 is offline   Reply With Quote
Old 01-15-2009, 09:38 AM   #4
I'm sure the tub only needs 120V 20A. It's an older one.
OK, so back to the drawing board... Is it the romex in the 1/2" conduit that is the problem? Should I put a junction box in the basement that brings in 12-2 romex, connect that to THHN, and send the THHN to the hot tub through the outdoor conduit? Then have a junction box/outlet in the tub enclosure?
Does the circuit need to be on a GFCI breaker, or is the GFCI on the hot tub end OK for that?
Old 01-15-2009, 10:22 AM   #5
Rewards Points: 246
Read this and any other information you can BEFORE proceeding! http://www.spaspecialist.com/oct98.html
This is not for a DIY'er unless you are certain to follow instructions. There is help here too. Please be careful.
Old 01-15-2009, 11:58 AM   #6
thanks for the link and concern for my safety. i've included this hot tub install on my permit for the wiring on my new home addition i'm building. so everything will be inspected and up-to-code. i've got a good handle on wiring the circuits for the outlets and lights in the new bed/bath i've put in, but i'm not so sure about outside stuff - like the hot tub.
the hot tub was previously owned by friends who are moving. i'm sure things have changed in the 8 years since it was first installed, but the wiring description in my first post is how the pro hot tub guys initially installed it. except they didn't even have a grounding rod.
i just want to install it correctly and not get any weird looks from the inspector
Old 01-15-2009, 12:27 PM   #7
Rewards Points: 508
Send a message via AIM to theatretch85
I believe one of the big no-no's is the bare ground wire supplying the circuit for the hot tub. My understanding is it must be fully insulated. Also, romex is never allowed in conduit of any sort in any wet location. My reccomendation would be to run conduit and THWN directly from your panel to the new outlet. Pools and Hot tubs have some very strict requirements for the electrical service, I'd suggest you search the forums here for pool or hot tub related threads as this has all been discussed on here earlier.
theatretch85 is offline   Reply With Quote
Old 01-15-2009, 01:03 PM   #8
Agreed!
Also Agreed!
Or it min. you install a disconnect box on the back of the house and run romex inside the house from the panel to the disconnect box or juction box then run THWN in conduit to the disconnect at the spa.
We need more info on this spa tho. Is this a hardwired spa or does it have a plug. (I have not even seen one with a plug or one that's 110 put outdoors)
Any outdoor plug is going to have to be GFIC either on the plug or on the circuit breaker no matter whats getting plugged into it. That's required.
integlikewhoa is offline   Reply With Quote
Old 01-15-2009, 02:17 PM   #9
thank you for the replies.
the spa info is in the first post, but basically, it is an older (8-year old) spa that needs a single 120V, 20A circuit. The spa has a GFCI plug.
would it be OK to run 12-2 romex in the house to a junction box in the basement near where the power needs to go outside. then junction some 12g THWN to the romex and send it to the hot tub using 1/2" flex outdoor conduit? the conduit would be under a deck, does it need to be buried? the conduit will be underground near the spa because it needs to come up into the spa enclosure from below grade. the male spa GFCI plug is inside this enclosure.
Old 01-15-2009, 02:52 PM   #10
Rewards Points: 900
I believe that, despite your spa having its own GFCI on the plug, you must install a GFCI receptacle outside at the spa, or a GFCI breaker in your panel.
The outdoor receptacle must have a cover that keeps it waterproof while the plug is in - the bubble type of cover.
I don't know for sure, but I think you could use type UF cable instead of the conduit, if that suits the installation. Again, you need to read the specific code for pools and spas.
Ultrarunner2017 is offline   Reply With Quote
Old 01-15-2009, 04:19 PM   #11
Yes.
If you run UF cable, which is just like NM with a more weatherproof sheath, you could run it thru the house then sleeve the outside portion with nonmetallic flex under the deck to the tub.
The flex will have to be rated for underground and buried 18". PVC will work nicely underground also.
220/221 is offline   Reply With Quote
Old 01-15-2009, 04:27 PM   #12
Originally Posted by 220/221 View Post
Yes.
UF for an outdoor hot tub? Doesn't that violate a code or two? I still want know if this thing is really a "hot tub." 20A, 120V? I don't see the water getting very warm during the winter...
Old 01-15-2009, 05:03 PM   #13
I dont know about the hot tub either, but I think codes are going to be different sinc basicly he is putting a outdoor outlet or plug and what he plugs into it is his deal. Its not a common hardwired with disconnect hot tub. If you pull permits and install an outdoor plug for what ever. Then later decieded to plug in a let say a moveable hot tub i dont think you would have a problem.
Like what was said tho. All outdoor outlets need to have some type of GFIC. On the plug or on the breaker up to you.
UF cable (like romex but gray and waterproof shield) would work and can be run the entire way. Also what you sugested would work to.
Old 01-15-2009, 07:17 PM   #14
Licensed electrician
Rewards Points: 1,884
UF cannot be used for a hot tub. Like the NM the ground wire is not insulated, it is only covered.
Also do NOT drive a grounding rod at the tub.
Old 01-15-2009, 07:40 PM   #15
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
The equipment grounding conductor only has to be insulated from where it leaves the inside of the house to it's termination point at the hot tub.
Magnettica is offline   Reply With Quote
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
Exposed Romex Questions bakerhouse Electrical 1 05-13-2008 11:15 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 09:33 AM
Romex to BX fifaboy Electrical 1 02-27-2005 04:12 PM
