Old 01-17-2013, 06:51 PM   #1
OK to fold wire ends to get more grip in receptacle connection?
Just purchased the last dryer receptacle they had in town.
What I don't like about it, is that there seems to be quite a bit of "wiggle" room since the bottom of the connection is flat. The wire in the picture is 10 gauge.
Would it be OK to fold the wire, as pictured below, to get a more positive grip?
roger r. is offline   Reply With Quote
Old 01-17-2013, 07:16 PM   #2
Semi-Pro Electro-Geek
I don't really know if UL or the manufacturer has an opinion on that. I have done it many times.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-17-2013, 08:08 PM   #3
Licensed electrician
There should be no need to double over the conductor.
J. V. (01-18-2013)
Old 01-18-2013, 11:28 AM   #4
Thanks for the replies thus far guys.
I would be have preferred there be a "v" shaped bottom platform or an old-style basic screw connection...something with more "bite". Folding the wire would give more surface area and give more holding power.
I would just feel more comfortable doing it in this manner as it seems more solid.
Is there any safety or code reason not to fold the wire?
Would most pros just screw it in as is?
Old 01-18-2013, 12:41 PM   #5
I've never had to fold a wire that size to get a good firm grip/connection. However I do that frequently with small gauge electronics wire.
And I would do that with the above too if it did not have a good strong grip on the wire - say I could pull the wire out or be able to wiggle it after it was tightened. A loose connection WILL cause trouble!
What gauges of wire does that receptacle say it can be used with?
Billy_Bob is offline   Reply With Quote
Old 01-18-2013, 02:00 PM   #6
AWG 10-4
AL or CU 75 degrees Celsius
no mention of using solid or stranded wire
Old 01-18-2013, 02:43 PM   #7
Well it *should* work with #10, however I'm finding these days that things "don't work" like they should (China manufactured stuff), so I need to modify things or fix things to get them to work...
So just another example of such a product! Bend the wire...
Old 01-21-2013, 09:24 AM   #8
Thanks Billy.
I guess I was being a little paranoid for nothing.
Cooper is an established, well known manufacturer.
I can only assume that from the good number of views this thread has received, if something was drastically wrong or dangerous, more people would have chimed in.
BTW (for the benefit of people reading this thread) written in tiny, barely visible text on the back of the all-plastic, white dryer outlet made by Leviton, it says that 8 gauge wire minimum is to be used. So It is unsuitable for those who have their boxes wired with 10 gauge.
Old 01-21-2013, 12:08 PM   #9
Stupid design flaw considering most dryers are wired with #10 copper.
Old 01-22-2013, 08:40 AM   #10
The warning is written so small that it fringes on deceitfulness. Probably an attempt at legal "butt-protectionism"...What? Didn't you read the fine print?
3 wire stove connection bgoldie Electrical 13 03-01-2011 01:29 PM
wire connection peteracki Electrical 6 05-18-2010 07:12 AM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
3 wire connection for new kitchen stove rjniles Electrical 4 09-13-2007 01:59 AM
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
