-   -   is this ok ? (http://www.diychatroom.com/f18/ok-155558/)
Fix'n it 09-02-2012 09:05 AM
is this ok ?
i ran some romex into a metal box. the box has the correct romex clamp, but it didn't have a ground screw. so i looped the ground wire, so that when the clamp was tightened (but not over tightened). the clamp made the ground connection. this is a junction box.
Rochsolid 09-02-2012 09:19 AM
Get a ground screw.
rjniles 09-02-2012 09:21 AM
Will not fly, you need a green ground screw in the back of the box or a ground clip at the edge of the box. You are in a Chicago suburb, are you allowed to use NM cable?
http://www.homedepot.com/catalog/pro...12e420_300.jpg
http://www.homedepot.com/catalog/pro...fe5c50_300.jpg
Fix'n it 09-02-2012 09:28 AM
thats what i thought. i will get some of those clips.
i am far enough away from chicago that i can use NM
jbfan 09-02-2012 10:49 AM
The screw does not have to be green, and it is a 10/32
