Ohms At 110 Outlets With The CB Open? - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 07:23 PM   #46
Rewards Points: 506
Originally Posted by Yoyizit
In this case 250A would flow for one cycle or so of 60 Hz until the CB tripped.
What?? I said properly installed and properly operating.
jlmran is offline   Reply With Quote
Old 02-17-2012, 07:25 PM   #47
An appliance with the hot connected to the ground will cause a heavy current to flow for a short period.
Right?
Old 02-17-2012, 07:26 PM   #48
Rewards Points: 506
Right?
Not necessarily...did you see my light bulb example above?
Old 02-17-2012, 07:31 PM   #49
Yes, the filament limits the current to reasonable values.
It is not usually said that "the hot is connected to the neutral" if a filament, resistor, motor, inductor, capacitor or other reasonably high impedance intervenes.
Old 02-17-2012, 07:39 PM   #50
Rewards Points: 506
I don't disagree. I know that it is not usually said as such. But, nobody can deny that energized conductors are in fact electrically connected to "ground". It's a strange concept.
Old 02-17-2012, 07:47 PM   #51
If it's a circuit then every circuit node is connected to every other node.
For house wiring a reasonable 120v load is 8 ohms (or less for short periods, like a welder) and a half-ohm or more for long periods is a "short." The long period and the short period depend on the CB's trip curve.
Old 02-17-2012, 09:43 PM   #52
I=E/R
a7ecorsair's Avatar
Originally Posted by jlmran View Post
But, in properly connected and properly operating 120v devices, the hot is always connected to ground.
Well not really. The hot is connected to the load and the load is connected to the grounded conductor.
a7ecorsair is offline   Reply With Quote
The Following 3 Users Say Thank You to a7ecorsair For This Useful Post:
Missouri Bound (02-17-2012), plummen (02-17-2012), rjniles (02-17-2012)
Old 02-17-2012, 10:24 PM   #53
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Well an energized conductor is just that ,a conductor.
Untill its physically conected through a load you can have no connection to neutral or ground without what I refer to as the big bang theory!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Can these outlets be grounded? KDOC Electrical 28 01-12-2012 08:39 PM
New Outlets on 15 amp line RocketManZ Electrical 20 10-24-2011 05:52 PM
Replacing old outlets (grounded vs none) Sonya_ Electrical 14 10-07-2011 11:37 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
