Ohms At 110 Outlets With The CB Open? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 07:35 AM   #31
Rewards Points: 3,130
Originally Posted by ddawg16 View Post
My Fluke handles it just fine....beeps at me to let me know I'm on the wrong range....
Simpson 260? Someone must have put in the wrong fuse...the ohms range is fuse protected....real small fuse....chances are it got blown and someone put in a larger amperage....
Read my post again. The 260 was set to measure microamps, not ohms.
Old 02-17-2012, 07:40 AM   #32
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by jlmran View Post
In properly connected and properly operating 120v devices, the hot is always connected to ground.
rrolleston is offline   Reply With Quote
Old 02-17-2012, 07:42 AM   #33
Rewards Points: 506
Originally Posted by rrolleston
Why are you confused?
jlmran is offline   Reply With Quote
Old 02-17-2012, 07:47 AM   #34
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Can you explain this?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-17-2012, 07:51 AM   #35
Rewards Points: 506
Think about a simple light bulb and follow the current path.
The hot is connected to the filament, which is connected to the neutral, which is bonded to the EGC at the panel.
Old 02-17-2012, 10:25 AM   #36
JOATMON
ddawg16's Avatar
Rewards Points: 1,972
It has been about 20 years since I looked inside my Simpson 260....but I believe it has a fuse for the microamps range
ddawg16 is online now   Reply With Quote
Old 02-17-2012, 10:42 AM   #37
Rewards Points: 3,256
Speaking of old meters and not looking in them for a while, we have 2 similar Tripletts here at work. Yesterday, the ohm scale was getting weak in one and come to find out they use a weird 30 volt battery.
zappa is offline   Reply With Quote
Old 02-17-2012, 10:58 AM   #38
Originally Posted by dmxtothemax View Post
Could be phantom voltage !
PVs are AC, the ohm test current is DC, so it shouldn't register on the meter.
Old 02-17-2012, 11:57 AM   #39
rditz's Avatar
Originally Posted by a6pilot View Post
I get 18-20 oms accross my 110 outlets with the CB open. Why or is this normal?
take the outlet off of the wires and measure it.
then measure at the wires. in both cases you should be getting a reading of infinity. if not, then go to the next receptacle and repeat the above steps, continue until you find the cause of your reading.
rditz is offline   Reply With Quote
Old 02-17-2012, 12:54 PM   #40
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Well, the OP logged out eight minutes after making this one and only post two days ago, and hasn't been back since.
I say we ignore this until he has the decency to reply back.
Speedy Petey is online now   Reply With Quote
Old 02-17-2012, 01:52 PM   #41
Rewards Points: 506
If we ignore all the 1-hit wonders, what will we have to debate???
The Following User Says Thank You to jlmran For This Useful Post:
plummen (02-17-2012)
Old 02-17-2012, 03:36 PM   #42
Missouri Bound's Avatar
But, in properly connected and properly operating 120v devices, the hot is always connected to ground.
....well....we can always debate this...
Do you want it your way or the right way?
Old 02-17-2012, 05:14 PM   #43
Rewards Points: 506
Is it inaccurate?
Old 02-17-2012, 07:05 PM   #44
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Originally Posted by plummen View Post
Itll probably just make the meter buzz or blow a fuse inside of it,I dont think thered be many fireworks unless you had some $5 chinese meter
Or you did like I did and solder the fuse terminals together because you could not find a replacement fuse the last time you screwed up. That was kind of cool. It was a cheap meter, so I did not care too much, but I would not recommend anyone try this. Do as I say, not as I do.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 02-17-2012, 07:15 PM   #45
In this case 250A would flow for one cycle or so of 60 Hz until the CB tripped.
Can these outlets be grounded? KDOC Electrical 28 01-12-2012 08:39 PM
New Outlets on 15 amp line RocketManZ Electrical 20 10-24-2011 05:52 PM
Replacing old outlets (grounded vs none) Sonya_ Electrical 14 10-07-2011 11:37 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
