Ohms At 110 Outlets With The CB Open? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 07:51 AM   #16
I=E/R
a7ecorsair's Avatar
Originally Posted by a6pilot View Post
I get 18-20 oms accross my 110 outlets with the CB open. Why or is this normal?
It is probably normal if you didn't unplug everything in the circuit. Wall warts, alarm clocks, and answering machine could still pass current if plugged in.
BTW, you should call you AE to fix this.
a7ecorsair is offline   Reply With Quote
Old 02-16-2012, 09:03 AM   #17
Originally Posted by Speedy Petey View Post
And you say this why? Did someone in the room with you get annoyed when they read it?
Jesus.
Old 02-16-2012, 09:13 AM   #18
Rewards Points: 3,130
Originally Posted by AllanJ View Post
Never try to measure ohms or continuity with the power on.
You can fry the meter.
Correction: you WILL fry the meter.
Not quite the same, but when I was teaching electronics in the Navy, one of the students set his Simpson 260 multimeter on the microamp scale and plugged the leads into a wall socket. Result wasn't pretty.
Old 02-16-2012, 09:51 AM   #19
I=E/R
a7ecorsair's Avatar
Did it bent the needle or just fry the coil?
Did you make him/her use ohms law and run the numbers so the learned why?
Old 02-16-2012, 01:04 PM   #20
Actually, it did both. As I recall, the fellow ended up failing the course.
Old 02-16-2012, 01:10 PM   #21
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
My Fluke handles it just fine....beeps at me to let me know I'm on the wrong range....
Simpson 260? Someone must have put in the wrong fuse...the ohms range is fuse protected....real small fuse....chances are it got blown and someone put in a larger amperage....
The Following User Says Thank You to ddawg16 For This Useful Post:
plummen (02-16-2012)
Old 02-16-2012, 07:51 PM   #22
dmxtothemax's Avatar
Rewards Points: 5,610
What did you measure it with ?
Did you use a digital type meter ?
If so, these types of meters can give ambiguase readings !
Try it again with a anologue type meter !
Could be phantom voltage !
dmxtothemax is offline   Reply With Quote
Old 02-16-2012, 08:10 PM   #23
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Originally Posted by mpoulton View Post
It's alarming because using a resistance meter on a circuit that is wired to a power source is something that should only be done if you know what you're doing. Accidentally trying to measure the resistance of a power source produces a fireworks display. I think it's fair to say that if someone is perplexed by these results, they shouldn't be using an ohmmeter on anything that's connected to the panel.
One should also not use a multi meter into an active outlet when it is actually set to amps.
Learn from my fail. Always double check where you set your meter before you put it into something. (this also goes for another device, but I wont go there)
As for the ohm readings, if you read from neutral to ground, you SHOULD get a reading, and it should be rather low. From neutral to hot, it should be technically infinite as the hot and ground should never be connected in any way. This is assuming nothing is plugged in of course.
A small random tidbit of useless information: Phone lines are actually tested using a voltage, resistance and capacitance check. A test is done from tip to ground, ring to ground and tip to ring. A proper line in good condition should show no voltage, 999k resistance (the max reading it will display) with and low capacitance such as 0.05 and tip to ring slightly higher. tip and ring should be balanced. A faulty phone set or bad wiring are things that can cause these readings to change. Capacitance is also a good ballpark way of determining how far the house is from the CO. The higher the reading, the farther it is. The two wires running next to each other for km's creates a very basic capacitor.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 02-16-2012, 10:08 PM   #24
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Itll probably just make the meter buzz or blow a fuse inside of it,I dont think thered be many fireworks unless you had some $5 chinese meter
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-16-2012, 10:10 PM   #25
plummen's Avatar
Originally Posted by curiousB View Post
This is why I love my clamp on ammeter. Just clamp it around the hot wire on the breaker and see what current is being drawn. I only spent $25 or so for it. It's not a Fluke but good enough for my usage.
I got it from harbor freight tools.
That would be amps not ohms ,or holmes as they say on that home inspector dudes show!
Old 02-16-2012, 10:20 PM   #26
Missouri Bound's Avatar
Wow...25 answers and the OP hasn't come back....great job
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Speedy Petey (02-17-2012)
Old 02-16-2012, 10:21 PM   #27
Rewards Points: 506
Another Vanilla Ice.
jlmran is offline   Reply With Quote
Old 02-16-2012, 10:25 PM   #28
Rewards Points: 506
But, in properly connected and properly operating 120v devices, the hot is always connected to ground.
Old 02-17-2012, 05:41 AM   #29
Master Electrician
Rewards Points: 3,966
Say what??
brric is online now   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
a_lost_shadow (02-17-2012), plummen (02-17-2012)
Old 02-17-2012, 07:10 AM   #30
Rewards Points: 506
Originally Posted by brric
Say what??
In properly connected and properly operating 120v devices, the hot is always connected to ground.
Can these outlets be grounded? KDOC Electrical 28 01-12-2012 08:39 PM
New Outlets on 15 amp line RocketManZ Electrical 20 10-24-2011 05:52 PM
Replacing old outlets (grounded vs none) Sonya_ Electrical 14 10-07-2011 11:37 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
