Ohms At 110 Outlets With The CB Open? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 05:25 PM   #1
Wink
ohms at 110 outlets with the CB open?
I get 18-20 oms accross my 110 outlets with the CB open. Why or is this normal?
a6pilot is offline   Reply With Quote
Old 02-15-2012, 05:30 PM   #2
You have something plugged into another plug on the same circuit?
fdiddy is offline   Reply With Quote
Old 02-15-2012, 05:31 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Why would you be checking this???
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (02-15-2012), hawkeye11 (02-15-2012), Mikenra (02-16-2012), plummen (02-16-2012)
Old 02-15-2012, 06:31 PM   #4
Rewards Points: 6,652
Okay. And your point is?
The Following 3 Users Say Thank You to gregzoll For This Useful Post:
Old 02-15-2012, 08:07 PM   #5
If nothing is plugged into any outlet and all switches are off, then no - you should read many megohms or gigaohms.
If something is plugged into one or more outlets, then maybe. The cold resistance of a 50w incand. bulb could read like this.
If your meter has a diode check you may get even more puzzling readings from these outlets.
What's even more difficult to explain is why this kind of question annoys people.
I guess it's because you're first supposed to have a purpose in making measurements, rather than making measurements first and then wondering what they could mean.
Old 02-15-2012, 09:02 PM   #6
Rewards Points: 1,500
Never try to measure ohms or continuity with the power on.
You can fry the meter.
Old 02-15-2012, 09:27 PM   #7
And you say this why? Did someone in the room with you get annoyed when they read it?
Old 02-15-2012, 09:29 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,922
It's alarming because using a resistance meter on a circuit that is wired to a power source is something that should only be done if you know what you're doing. Accidentally trying to measure the resistance of a power source produces a fireworks display. I think it's fair to say that if someone is perplexed by these results, they shouldn't be using an ohmmeter on anything that's connected to the panel.
mpoulton is offline   Reply With Quote
The Following 5 Users Say Thank You to mpoulton For This Useful Post:
frenchelectrican (02-15-2012), Jim Port (02-16-2012), Mikenra (02-16-2012), Missouri Bound (02-15-2012), Speedy Petey (02-15-2012)
Old 02-15-2012, 09:42 PM   #9
Rewards Points: 506
What is an om?
jlmran is offline   Reply With Quote
Old 02-15-2012, 09:44 PM   #10
Master Electrician
Rewards Points: 3,824
Originally Posted by jlmran View Post
What is an om?
That's what one chants when meditating.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
gregzoll (02-16-2012), plummen (02-16-2012)
Old 02-15-2012, 09:46 PM   #11
Rewards Points: 506
Jackie Gleason did it well in a famous (?) Trans-Am movie.
Old 02-15-2012, 09:47 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,458
I would look for a door bell or HVAC transformer.....your 'ohm' reading sounds about right for one of those....
ddawg16 is online now   Reply With Quote
Old 02-15-2012, 09:53 PM   #13
Master Electrician
Smokey and the Bandit?
Old 02-15-2012, 09:54 PM   #14
Rewards Points: 506
Nope...Smokey and the Bandit II.
Old 02-16-2012, 06:32 AM   #15
Rewards Points: 810
This is why I love my clamp on ammeter. Just clamp it around the hot wire on the breaker and see what current is being drawn. I only spent $25 or so for it. It's not a Fluke but good enough for my usage.
I got it from harbor freight tools.
curiousB is offline   Reply With Quote
Can these outlets be grounded? KDOC Electrical 28 01-12-2012 08:39 PM
New Outlets on 15 amp line RocketManZ Electrical 20 10-24-2011 05:52 PM
Replacing old outlets (grounded vs none) Sonya_ Electrical 14 10-07-2011 11:37 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 08:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
