-   -   ohms at 110 outlets with the CB open? (http://www.diychatroom.com/f18/ohms-110-outlets-cb-open-133863/)
a6pilot 02-15-2012 06:25 PM
I get 18-20 oms accross my 110 outlets with the CB open. Why or is this normal?
fdiddy 02-15-2012 06:30 PM
You have something plugged into another plug on the same circuit?
Speedy Petey 02-15-2012 06:31 PM
Why would you be checking this??? :huh:
gregzoll 02-15-2012 07:31 PM
Okay. And your point is?
Yoyizit 02-15-2012 09:07 PM
If nothing is plugged into any outlet and all switches are off, then no - you should read many megohms or gigaohms.
If something is plugged into one or more outlets, then maybe. The cold resistance of a 50w incand. bulb could read like this.
If your meter has a diode check you may get even more puzzling readings from these outlets.
What's even more difficult to explain is why this kind of question annoys people. :laughing:
I guess it's because you're first supposed to have a purpose in making measurements, rather than making measurements first and then wondering what they could mean.
AllanJ 02-15-2012 10:02 PM
Never try to measure ohms or continuity with the power on.
You can fry the meter.
Speedy Petey 02-15-2012 10:27 PM
And you say this why? Did someone in the room with you get annoyed when they read it?
mpoulton 02-15-2012 10:29 PM
It's alarming because using a resistance meter on a circuit that is wired to a power source is something that should only be done if you know what you're doing. Accidentally trying to measure the resistance of a power source produces a fireworks display. I think it's fair to say that if someone is perplexed by these results, they shouldn't be using an ohmmeter on anything that's connected to the panel.
jlmran 02-15-2012 10:42 PM
What is an om?
brric 02-15-2012 10:44 PM
Originally Posted by jlmran (Post 854688)
What is an om?
That's what one chants when meditating.
jlmran 02-15-2012 10:46 PM
Jackie Gleason did it well in a famous (?) Trans-Am movie.
ddawg16 02-15-2012 10:47 PM
I would look for a door bell or HVAC transformer.....your 'ohm' reading sounds about right for one of those....
brric 02-15-2012 10:53 PM
Smokey and the Bandit?
jlmran 02-15-2012 10:54 PM
Nope...Smokey and the Bandit II.
curiousB 02-16-2012 07:32 AM
This is why I love my clamp on ammeter. Just clamp it around the hot wire on the breaker and see what current is being drawn. I only spent $25 or so for it. It's not a Fluke but good enough for my usage.
I got it from harbor freight tools.
