"off" Switch For 240v Steam Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 05:43 PM   #1
Question
"off" switch for 240v steam generator
I recently bought a thermasol steam generator system for a steam shower that I am installing in my house. It requires a 240v plug and I was wondering if I can install an "off" switch for something like this....just in case there is ever a problem, and I can't exactly get close to it to plug it out of the wall, and I need to power off the generator immediately.
Currently, the only way to kill power to it is by trekking downstairs to the garage and flipping the breaker.
Note that the setup instructions does not call for an "off" switch.
MarqoCristiano is offline   Reply With Quote
Old 03-19-2013, 05:49 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
So why do you want this? Just shut off the circuit breaker if you wanted, but really, it comes with preinstalled safety controls, so you only need a disconnect for the repair guy, not an emergency.
In a nutshell, you are over thinking this and wasting your time and money.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (03-19-2013)
Old 03-19-2013, 07:50 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,904
You could install a double-pole switch appropriately sized for the load, but it is really not necessary. If the current rating is 20A or less, you can find a relatively normal-looking double pole switch and mount it anywhere convenient. If it's more than 20A, you may have a hard time finding something attractive looking to do the job.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 03-19-2013, 09:31 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Fully agree.
This is also not something typically installed with a plug and receptacle. Every steam generator that I have seen or wired was hard wired with a service disconnect right near the unit.
Tags
240 volt , 240v , generator , steam , thermasol
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Transfer switch for generator Dave12vette Electrical 17 11-12-2012 08:39 PM
Generator output and Transfer Switch aquasport17 Electrical 3 07-12-2011 11:17 AM
Portable Generator Electrical Ground Earnie Electrical 35 01-18-2011 05:53 PM
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
