Off Peak Panel Loading - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 09:47 PM   #1
I=E/R
a7ecorsair's Avatar
In my new house the off peak panel will have electric baseboard branch circuits and a water heater.
I know that each branch circuit will be restricted to 80% of the rated load. What about the main? I currently have 11500 watts of baseboard and the 4500 watt water heater for a total of 16000 watts or 67 amps. I will need a couple more baseboard units. Not that I need to go this far, but could I add additional baseboard units up to about 90 amps or is the off peak main, (100 amps) limited to 80% too?
a7ecorsair is offline   Reply With Quote
Old 09-19-2010, 12:08 AM   #2
" Euro " electrician
frenchelectrican's Avatar
You can load them up to 80% due majtory of the off peak load is heating load { electric baseboard heat } and per NEC code the electric baseboard and electric water heater is consering a continuous load { A/C unit is not usaelly a contiounus load }
If you have room in off peak panel to add couple baseboard heater circuits then you can do that without issue.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
a7ecorsair (09-19-2010)
Old 09-19-2010, 09:06 PM   #3
I=E/R
a7ecorsair's Avatar
I'm going to tag one more thing on this thread. The code says panel boards cannot be in clothes closets. What constitutes a clothes closet? I will be installing my two panel board in a closet that has a trap door for access to the crawl space and will also be used for other storage and I was expecting to use it for jackets and other outer wear. Here is a picture. The main and off peak panels are on an outside wall behind the 36" door.
Old 09-19-2010, 10:45 PM   #4
I think you should be ok due it is behind the door but just wait until other guys to make sure they can confirmed this part is legit or not.
I am pretty sure but hang on.
Merci.
Marc
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
