Off-kilter Light Fixture In Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2009, 07:14 PM   #1
Question
Off-kilter light fixture in bathroom
I'm replacing an old light fixture in my bathroom.
The light hangs above a mirror. The black & white wires run across about 1" of wall below it to get to the outlet box behind the mirror.
New light has a black, white and bare ground.
Can I run the ground across 1" of wall to mount it to the ground in the outlet box?
It seems safe, but since it's bare and in a sometimes damp bathroom it makes me nervous.
Should I wrap it in electrical tape where it's exposed, or just tuck it inside the light fixture & leave it ungrounded?
bungalowgirl is offline   Reply With Quote
Old 03-16-2009, 07:27 PM   #2
A white and black wire is running behind the wall into the outlet box? Wires cannot be ran in such a way, they need to be in a cable, like romex.
Is there a way you can get pictures?
rgsgww is offline   Reply With Quote
Old 03-16-2009, 07:44 PM   #3
A black & white wire is running in front of the wall. Picture as requested!
The ground is on the left, wrapped in black electrical tape. Regular black & white on right. A mirror covers all of this and runs flush under the light fixture.
Old 03-16-2009, 07:47 PM   #4
That doesn't look very good...Do you think you can run romex (a type of cable) inside the wall to your fixture?
That looks like a fire hazard.
I hope that isn't your work BTW.
Old 03-16-2009, 07:53 PM   #5
Do you mean connect those to a romex, drop it in the wall, and connect the other end of the romex to the outlet box? Possibly, but I hesitate because I rent.
Just curious, which part is a fire hazard? The ground?
Old 03-16-2009, 07:55 PM   #6
Re: "I hope that isn't your work BTW."
Original was wired that way without the ground. I'm asking if it's okay to do it this way with the addition of the ground, taped off in that manner.
Old 03-16-2009, 07:58 PM   #7
With or without a ground, it is not OK to do it that way. Relocate the box to the proper position, behind the light.
220/221 is offline   Reply With Quote
Old 03-16-2009, 08:01 PM   #8
Lovely. That means buying a new mirror, the existing one is too tall.
Whole apt is rigged like this. Ceiling light in kitchen is mounted to a ceiling tile, no outlet box, no ground. Yay!
Old 03-16-2009, 08:05 PM   #9
You rent? ...the landlord should be the one that gets the things fixed, he should also know about the "fixes" that have been done.
Old 03-16-2009, 08:09 PM   #10
Landlord said it was okay to swap out the light. I also think the landlord is the one who rigged it this way in the first place.
Can I just cap & tape the wires in the outlet box and get rid of the light all together?
Old 03-16-2009, 08:17 PM   #11
You can certainly unscrew those wire nuts and remove the wires leading to the fixture. Ditch the electrical tape on the nuts, makes it look even worse. Make sure power is off first, by using a wiggy (little light up testers, very cheap)
Old 03-16-2009, 08:23 PM   #12
Cool, thanks for all the quick and thorough feedback.
Old 03-16-2009, 08:28 PM   #13
No problem.
Adding second light fixture in bathroom upcountryliving Electrical 2 06-28-2008 05:44 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Safety Concern related to bathroom light fixture sooner2k1 Electrical 3 01-10-2008 09:57 PM
Replacing Bathroom Light Fixture shapeshifter Electrical 1 02-05-2007 05:33 PM
