-   -   Odd Wire type (http://www.diychatroom.com/f18/odd-wire-type-170594/)
hpmaxim 01-30-2013 06:44 PM
Odd Wire type
There's a GFI receptacle on the exterior of my house. The wires running to it are not like anything I've ever seen. I believe the wiring runs into my attic, except when its in the attic it appear to be old rubberized NM-B cable (both the sheath and the insulators). So without further ado... Here's a photo. What type of wire is this?
http://i47.tinypic.com/igyy6g.jpg
joed 01-30-2013 06:46 PM
Add your location. I have not seen anything like that in Canada.
hpmaxim 01-30-2013 06:48 PM
I'm on the East Coast of the US, and have not seen anything like it either. The house was built in 1947. I've seen wiring in the house that seems to range from armored with rubberized insulation, to aluminum wiring, to modern stuff. So figure it could be anything made in the last 70 years.
sgip2000 01-30-2013 06:57 PM
Looks like it could be older UF cable.
Jim Port 01-30-2013 06:58 PM
That is still available at the big box stores on rolls. I believe it is for direct burial. I have never used it.
kbsparky 01-30-2013 07:24 PM
THAT is submersible well pump cable. Not listed for premises wiring.
hpmaxim 01-30-2013 07:27 PM
Jim, so you agree with sgip2000 that its older UF? Any issues with it? What bothers me is that it appears to be connected to some old rubberized NM cable somewhere in the exterior wall (sandwiched between plaster on the inside and two layers of siding on the outside) -- with insulation in between. And to make matters worse, there are windows above it, so it has to go horizontal (through studs)... So if its stapled in, I'm done....
mpoulton 01-30-2013 08:04 PM
I'm with KB - I think it's submersible pump cable. The colors are different than usual, but they're also not normal for any other use. The construction looks exactly like pump cable.
jagans 01-30-2013 09:35 PM
That is not a waterproof box either.
Deres water gittin in dare Verne! lookidat RUST! :huh:
Jim Port 01-30-2013 09:53 PM
Why do you think a box mounted in a wall needs to be waterproof?
jlmran 01-30-2013 10:12 PM
^ Yep
joed 01-31-2013 08:57 AM
I don't see any of the cable marked with white. It appears to be red, black and green. It can only be used 240 volt applications.
mterry 01-31-2013 09:07 AM
Exterior wall, should have exterior in-use type cover
jlmran 01-31-2013 12:38 PM
The comment was about the box. The reply was about the box. Nobody mentioned the cover. The cover is not in the photo. Jim Port's comment/question was spot on.
Why is everybody so confused??:laughing:
hpmaxim 01-31-2013 01:28 PM
joed, I don't see any cable marked with white either. I thought that was a bit odd. I can't see why a cable intended for 240V would be an issue at 120V though (in fact, I didn't know there were cables intended for 240V vs 120V). Regular NM-B cable is rated to 600V. The stranded nature is kind of odd though.
There was a cover over it that I removed that consists of a rubber/foam gasket and a metal cover with a spring loaded hinged door (with rubber/foam gasket on the door). I removed the cover so that I could inspect everything, its going back on.
If I can figure out how to replace it, I'd love to, but like I said, its not exactly in an easy to get at place.
Anyway, thanks for the feedback.
