Odd Thermostat Set-up, Help Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2007, 01:43 PM   #1
Odd Thermostat set-up, help needed
Hello Everyone,
I wondered if someone could help. I bought a new programmable thermostat (White Rodgers 150) and it has terminals for G, Y, O, W, B and a jumpered RH and RC.
However, my old Carrier one had wires hooked up to W2, Y, R, G, L, C, and E.
Would anyone have any clue how to re-connect?
Thanks.
Dan1 is offline   Reply With Quote
Old 10-07-2007, 02:21 PM   #2
see the thread "facts about thermostats" in the HVAC forum by carrierman.
redline is offline   Reply With Quote
Old 10-07-2007, 02:21 PM   #3
Is your unit a heat pump?
Master Electrician
jwhite is offline   Reply With Quote
Old 10-08-2007, 11:12 AM   #4
Rewards Points: 236
What color are the wires you plan to connect to the thermostat?
Also, do you have the manual that came with the unit? You may find your answer there.
A call to the new thermostat dealer/manufacturer may be able to tell you. How about the instruction manual that you got. It has a wiring diagram.
Google the thermostat. You may find help there too.
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 09:11 AM
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 01:02 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 12:20 PM
