Odd Outlet.... Trying To Change To A 3 Prong Gfi - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 08:34 PM   #1
Rewards Points: 14
odd outlet.... trying to change to a 3 prong gfi
Hello,
I am just moving into a house in ventura county and it is definitely a fixer upper.... Anyway long story short I am fixing some of the stuff and replacing things. The house was built in the late 50's and it has a few odd outlets. I am trying to replace them with 3 prong GFI's the issue is when I go to the local home depot and a few other hardware stores in the area people say they have never seen an outlet like this. I have attached a picture of one of them over the counter in the kitchen.... Any ideas on how to best convert this to a three prong gfi? also can anyone identify what kind of outlet this is? I've tried googling but can't find anything similar.
Thanks!
socrates is offline   Reply With Quote
Old 06-10-2012, 08:46 PM   #2
Missouri Bound's Avatar
No picture posted. Can you describe the outlet?
Do you want it your way or the right way?
Old 06-10-2012, 08:47 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Soc, Your GFCI pic did not appear.
Here is a link showing the most common type GFCI receptacle
http://www.amazon.com/Leviton-X7599-.../dp/B0048WPV4Q
Is this what you are looking for?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-10-2012, 08:48 PM   #4
Rewards Points: 14
sorry
Sorry I screwed up on the link... it's up now.
Old 06-10-2012, 08:51 PM   #5
Tht's a very old quad receptacle. Just how old is the house?
The Following User Says Thank You to Missouri Bound For This Useful Post:
gregzoll (06-10-2012)
Old 06-10-2012, 08:54 PM   #6
Rewards Points: 14
The house is late 50's the weird thing is that there are only a couple outlets like that... One in the kitchen one in the living room and the whole back room behind the garage. so like 6 outlets total.
Old 06-10-2012, 08:54 PM   #7
Hell of a fella
Rewards Points: 27
just swap out with a gfci receptacle like palibob posted a link to...they can be found at any hardware store. they do not make those receptacles anymore i would bet.
DrumBum is offline   Reply With Quote
Old 06-10-2012, 08:55 PM   #8
Hell of a fella
Rewards Points: 27
also probably will need to label "no equipment ground"
Old 06-10-2012, 09:37 PM   #9
Rewards Points: 14
cool,
Thanks I just wanted to make sure there weren't any tricks to replacing them. I'd rather not start a fire or get zap'ed.
Old 06-11-2012, 11:55 AM   #10
Rewards Points: 80
If you plan to live in this house, you might want to consider an upgrade. Remove old wire and install new? Think about this. When will be your best opportunity to do this job? If you are moving in, seems now might be the best time. Before you actually move in.
One more thing. Your picture is to big for the forum. LOL.
Old 06-11-2012, 11:38 PM   #11
Tool Geek
PaliBob's Avatar
Originally Posted by J. V. View Post
.........you might want to consider an upgrade........
J.V. Is right, Since you are in a 1950's
SC house there is a good chance your house is wired with Flexible Conduit.
In the 80's I moved into a 2400 sq ft 1954 Southern CA house that was
originally wired with Flex. There was no Main and just six 15 & 20 amp
breakers. Wow!, what they got away with in the 50's!
I ended up moving the meter, pulling in a 200 Amp service feeding three
new panels with 54 breakers.
The advantage of rewiring in a house wired with flex is that the original flex
runs had only 2 or 3 conductors (one or two circuits). To add circuits I pulled
out the original 1950's wire and pulled in all 12 gauge THNN in a lot of colors.
In the 80's I think the max fill for 1/2" Flex was 13 twelve gauge conductors.
I ran green grounds so on a few of the runs I was up to the limit of 13.
The code has changed now so the max fill is nine 12AWG conductors, but
that still gives you plenty of room to add several circuits in a 50's style flex.
http://www.jhlarson.com/ind_tables/fill/flexfill.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-12-2012, 12:16 PM   #12
Rewards Points: 80
I am not a fan of using flex for this type of project. NM or MC is what I would recommend. NM being the best choice.
Old 06-13-2012, 04:08 AM   #13
Tool Geek
PaliBob's Avatar
Adding or modifying wiring circuits on existing structures is generally easier with NM wiring,
especially since that is the most common anyway. However if the OP already has Flex conduit,
then he is better off maximizing the use of the existing conduit runs to add new circuits and/or
increase wire size.
I did not use any MC in my remodel but I did use NM for new runs and all EMT in the garage.
There are some areas in the country where EMT is required for any remodeling.
Disclaimer
& Stay Safe
.....Bob Lavery
change outlet to hot add ceiling fan with light bella3 Electrical 2 06-02-2012 01:29 PM
No power after trying to change outlet - Help plz! dearly23 Electrical 22 12-27-2011 02:09 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Installing 3 prong outlet wwcpacwrc23 Electrical 3 10-24-2010 10:15 AM
220volt 3prong outlet swap to 4 prong rp1666 Electrical 4 08-20-2009 10:03 PM
