Odd Electrical Issues After Electrical Work - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2009, 03:53 PM   #1
Rewards Points: 81
Odd electrical issues after electrical work
I had my electrical meter outside upgraded, and my electrical panel upgraded from 100amps to 200amps.
They didn't touch anything else.
I have noticed a few things since. My TV now buzzes. It's an older tv (not flatpanel). The buzz comes from the back, inside.
A little boom box I had plugged in fried. It doesn't turn on now.
The power adapter plug to my tv cable box fried.
And now I even noticed that playing back mp3s on my computer sound really messed up and weird. I know, that's an odd one.
When I had an initial inspection on the house they said that the polarity was reversed on a lot of outlets. I am about to fix those, but that's still true.
I called the guys back that did the work and he noticed a bad switch and recommended I replace that because it could be shorting things out.
I'm definitely not blaming the guys that did the work the other day because they were very professional and did good looking work. I'm just wondering what would cause this stuff, and if there's anything I should look for.
99miles is offline   Reply With Quote
Old 10-09-2009, 04:55 PM   #2
Rewards Points: 81
I figured out with the audio playback on my computer it's the external speakers sounding REALLY out of phase. Did they just get fried too?? Ugh
Old 10-09-2009, 06:35 PM   #3
Rewards Points: 81
Sounds like it was a power surge.
Old 10-09-2009, 07:01 PM   #4
joed's Avatar
Rewards Points: 13,712
Sounds like a possible loose neutral. The voltage on one of your legs might be low whilethe other goes high.
Do you notice anything with the lights? Like some of them going brighter?
Old 10-09-2009, 07:07 PM   #5
Rewards Points: 81
Heh, I have no idea what that means, but I will keep an eye out for odd light issues tonight.
Old 10-09-2009, 07:15 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Yup. Loose neutral on a multi-wire circuit.
Can you call the electricians back who did the panel?
Speedy Petey is online now   Reply With Quote
Old 10-09-2009, 07:43 PM   #7
Rewards Points: 1,548
Plug in some incandescent ("old fashioned light bulb type") lights. If they are unusually dim or unusually bright, the you have a neutral problem and need to unplug all electronic equipment (including microwaves and also refrigerators and washing machines with digital readouts) from those circuits and get an electrician in as quickly as you can.
Hopefully there is a good circuit for the refrigerator. String an extension cord if needed.
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Electrical Circuit Doesn't Work kcrossley2 Electrical 11 05-21-2009 04:22 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 07:37 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
