OCD Kicking In Again - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 11:48 AM   #1
Rewards Points: 27
OCD kicking in again
Doing some work on the basement still and I'm running a 3 way light circuit to control hallway lights ect, so I have a 12/2 and a 12/3 run going to the box. I have been using regular Carlon single gang boxes that has the wire knockouts throughout the entire basement for light switches and outlet boxes where appropriate
and had a question about the 3 way application that I couldn't find an answer to in the code book.
Being I'm running a flat cable "12/2" with an oval cable "12/3" I didn't like the idea of using staples in that case so I'm securing them to the stud using stack-its. Does using stack-its suffice as proper mechanical securement in these types of boxes, or should I use a box that has a mechanical locking device on it for the NM? I know in the the other types of boxes there is actually a tab that locks the NM down in the box, vs having it just hang there and be secured within 8" by a staple. I'm just wondering if the wire would be properly secured being the stack-it's more or less guide the wire they don't lock it into a position. It's not a huge deal to get a different box and redo that one, but figured somebody on here would know the answer and point me to the location in the code book. Again I looked and didn't have any luck finding a reference. Thanks guys.
kossuth is offline   Reply With Quote
Old 06-07-2011, 11:55 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
Yes, stack-it count as being secured.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
kossuth (06-07-2011)
Old 06-07-2011, 12:47 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
I saw the header to the thread and thought it meant Over-Current Device
My bad
Kyle
Old 06-07-2011, 04:47 PM   #4
Rewards Points: 27
My bad
LOL...Thanks jbfan.
Old 06-07-2011, 05:26 PM   #5
Rewards Points: 1,016
Today I learned what a stack-it is - thanks!
Old 06-07-2011, 07:13 PM   #6
Rewards Points: 512
My bad
So we know you're not anal
Old 06-07-2011, 07:28 PM   #7
the Musigician
DangerMouse's Avatar
My bad
DM
Old 06-07-2011, 08:32 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Good one !
Kyle
Lennox Furnace not kicking on unless thermostat is turned off then on sharkbait HVAC 14 12-31-2010 12:27 PM
Central air compressor kicking in but not staying on EMkid HVAC 2 05-10-2010 06:36 PM
Furnace not kicking on mterracciano HVAC 1 01-29-2010 08:23 AM
Blower not kicking in Appalachian HVAC 2 12-10-2009 07:40 PM
Sprinkler Pump keeps kicking on and off while running Slimyjack Plumbing 2 06-21-2009 12:33 PM
