Occupancy Sensor Switch Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 04:53 PM   #1
Occupancy sensor switch problems
Im a facility's manger at a church and Im trying to install a occupancy sensor switch in the bathrooms, like many hospitals have now. Im running into an issue. After things are installed the florecent lights will not come on completely, they flickers or almost go ON/OFF repeatedly and I can hear the ballasts buzzing alot! I can fully turn the switch to the ON position and things are fine but in sensor mode its just about worthless.....also the switch is getting near hot, Id say 120-140 degrees.
This is a single pole switch
Leviton PR150-1LW 500w
dangerousatom is offline   Reply With Quote
Old 03-19-2011, 06:29 PM   #2
Master Electrician
Rewards Points: 3,964
According to what I have read those switches are only compatible with rapid start magnetic ballasts on flourescent fixtures.
brric is online now   Reply With Quote
Old 03-19-2011, 08:12 PM   #3
Ya I have seen that in other places on the web. The weird thing is I have one installed in a hallway that is setup the same and it works like a charm?!?
Installing 3-way occupancy sensor westbank Electrical 6 05-04-2010 05:08 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
