Occupancy Sensor Help - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 05:57 PM   #1
Im looking to install an Occupany Sensor in the garage on the main fluorescent light above. the Cooper brand sensors (from what ive read) dont work too well with fluorescent light fixtures.
ive read Leviton should work well with them possibly through their commercial line. probelm is they have well over 50 products to choose from and i dont know what specs i should be looking for.
Ive also read that you need to know if your fluorescent fixture has magnetic or electronic ballasts. if true, how can i tell by looking at the fixture which one i have?
Leviton Switches: http://www.leviton.com/OA_HTML/Secti...emsPerPage=All
thanks for any and all help anyone can provide
seasoned vet is offline   Reply With Quote
Old 08-09-2012, 07:56 PM   #2
Master Electrician
the ballast should say right on it if it's electronic or magnetic. If the fixtures fairly new it'll likely be electronic. The levitron switches are decent, lutron makes a better one but your looking at more money for it. I've done tons of occupancy sensors in office buildings, as long as you get the right switch to marry to your ballast you should have no problem at all.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-09-2012, 08:29 PM   #3
Sparky
Rewards Points: 510
I've had no problems with 'Sensor Switch' Cat # WSD(IR Only) or WSD-PDT (Ultrasonic/IR)
They do require a ground connection.
Techy is offline   Reply With Quote
Old 08-10-2012, 01:14 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 820
I just installed some Lutron occupancy sensors in my house....very happy with how they work.
Model MS-OPS2-WH (the WH means White).
They work for basically all lights....one of them is controlling some CFL's...the other an LED light.
three way switch with occupancy censor up and down stairs izzyam Electrical 8 03-19-2011 05:43 PM
Occupancy Sensors trclac Electrical 3 10-14-2010 01:14 PM
Problem with occupancy sensor Ultrarunner2017 Electrical 0 09-04-2010 08:43 PM
Installing 3-way occupancy sensor westbank Electrical 6 05-04-2010 06:08 PM
Longer On Time for Occupancy Sensor? Ultrarunner2017 Electrical 7 12-22-2009 09:03 PM
