Occupancy Sensor - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2009, 02:08 PM   #1
Occupancy Sensor
Hello,
I have a 40watt / 3.4amp LED driver. model number EL-LNCDRV40W
it converts ac to 12v dc. it powers 13' of LED lights...
i need it to work with an occupancy sensor. the one i got from HD does not work. im under the impression i need a LOW VOLTAGE occupancy sensor, but im not sure. the sensor will be mounted in a 3gang box, house current runs to the sensor, then to the transformer(led driver) i've called around and called the company and can find no info to help me.
here are some more specs on the driver:
Weight: 15 oz.
Length: 5.2 in.
Width: 2.3 in.
Depth: 1.6 in.
Input Voltage: 100V - 240V AC
Output Voltage: 12V DC
Rated Power: 40W
Rated Current: 3.4A
Frequency Range: 50-60 Hz
IP Rating: 67
Safety:
UL1310 Class 2, TUV EN60950, CB Report
PLEASE HELP...thanks!
Roy
RoyD is offline   Reply With Quote
Old 10-29-2009, 05:04 PM   #2
Why do you need a low voltage sensor? Control the 120 vac to the LED driver.
hayewe farm is offline   Reply With Quote
Old 10-30-2009, 04:58 AM   #3
Electrical Contractor
kbsparky's Avatar
You need to scrap those cheap occupancy sensors, and get one that requires the use of a neutral wire for proper operation. They cost more $$$, but will do the job.
-KB
Old 10-30-2009, 07:41 AM   #4
sorry, i dont need a low voltage sensor as in wired to 12v...i need one that can work with the transformer....i explained that poorly
thanks
Old 10-30-2009, 02:00 PM   #5
thanks
You need a sensor that gives you a relay contact closure as an output
or else you need a simple interface to have the sensor output power a relay, with contacts that can handle the LED thing.
You have a link to your LED light string? I'm curious whether it needs a constant current drive or that's handled internally in the string.
Old 05-11-2011, 01:47 PM   #6
Occupancy Sensor with LED's
I have the same problem and I'm using a Leviton PR180 Occupancy Sensor. I've installed the sensor and the switch portion works fine. The Auto on the other hand will not shut off the sensor. I think that the light dispersed by the LED's is in a spectrum that the sensor can detect, therefore the lights will not shut off. Does anyone know of a sensor that works with LED's? Mine gives off a cool white light.
mlovie is offline   Reply With Quote
Old 05-11-2011, 03:24 PM   #7
Rewards Points: 1,418
Some motion detectors or occupancy sensors require a minimum wattage of lights or other controlled loads in order to work. Some will not work with a transformer as the load, hence the need for a low voltage sensor, which goes "after" (downstream of) the transformer.
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
Cooper Motion Sensor Help needed please scoops Electrical 3 02-23-2012 11:39 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 11:30 AM
Occupancy Sensor: Did I wire it correctly? kohaiut Electrical 7 01-14-2009 11:13 PM
What type of wire to connect motion sensor to light? beezlebub03 Electrical 1 05-31-2008 02:16 PM
