#1 |
Obtain 120V 30 amp from 120/240 30 amp generator outlet
I've recently bought a generator that doesn't have a 120V 30 amp outlet like my previous ones. It has a 4 wire 120/240 30 amp outlet and some 120V 20 amp outlets. I would like to run my RV air conditioner with 30 amps and have wired the proper plug, but using only one of the hot legs. It appears to work fine, but I'm not sure that what I have done provides 30 amps. If not, how can I get the desired voltage and amperage? The manual doesn't address this at all.
Rick |
#2 | |
A "Handy Husband"
Obtain 120V 30 amp from 120/240 30 amp generator outletQuote:
Also, all the RV 110 volt AC units I have seen are 20 amp. You could run a 20 amp extension off the 20 amp receptacle on the gen set and plug the AC into the extension. If your RV has a 30 amp cord set the make a dog-bone adapter to let you plug the 30 amp cord into a 20 amp receptacle. I do this when I have my RV at home and I want to work inside and have the AC running. If you do this do not try to run anything else at the same time or you will trip the breaker on the gen set. Last edited by rjniles; 08-29-2009 at 07:13 PM. |
| Display Modes | |
| 240v Air Compressor to 120v help | ruacoltsnut | General Discussion | 10 | 11-11-2010 05:05 PM |
| Do you think a tool running at 240v works better than at 120v? | Piedmont | Electrical | 39 | 07-03-2009 10:50 PM |
| Help me understand the difference between 12v and 120v under cabinet lighting | niceguymr | Electrical | 4 | 05-31-2009 10:12 AM |
| How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase | wantsomegetsome | Electrical | 9 | 05-04-2009 11:49 AM |
| Understanding 120V branch loads in 100A 240V system | WaldenL | Electrical | 17 | 02-17-2009 10:15 AM |
