Old 11-12-2012, 11:26 AM   #1
Nutone Ventilation fan blowing in reverse direction...
Hi All, the bathroom fan Nutone 8663RP is blowing air into the bathroom of our new home, instead of sucking the humidity out through the vent. Anyone know how to reverse the direction of the fan? Is it a simple maneuver? Thanks much,
Rochester, NY
smokyjoe is offline   Reply With Quote
Old 11-12-2012, 11:28 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Not a fan motor problem, most likely a clogged vent.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 11-12-2012, 11:51 AM   #3
joed's Avatar
Did it ever work? Did someone replace the fan motor? If they did they got the wrong one. Ventilation motors are not reversible.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 11-12-2012, 01:05 PM   #4
J. V.'s Avatar
Might be installed upside down?
Old 11-12-2012, 05:31 PM   #5
deleted.
danpik is offline   Reply With Quote
Old 11-12-2012, 09:25 PM   #6
Rochester, NY
Did it ever work correctly ?
If so what has happened recently to change that ?
You might be able to remove the blades,
and put them back in upside down !
Did someone take them out to clean them maybe ?
dmxtothemax is offline   Reply With Quote
Old 11-12-2012, 09:28 PM   #7
gregzoll's Avatar
The Squirrel cage should only go in one way.
Old 11-12-2012, 11:02 PM   #8
Plus the fan damper should be sucked shut.Maybe you have a fan motor that was assembled wrong.
bobelectric is offline   Reply With Quote
Laminate Flooring Direction canadiandude Flooring 4 03-03-2012 05:19 PM
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing 1 09-07-2011 11:13 AM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 12:19 PM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 12:10 PM
