NuTone 8663RP Bath Light And Fan Repair - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 05:52 PM   #1
NuTone 8663RP bath light and fan repair
In my newly bought house, the bathroom ventilation fan/light is making a grinding noise and shudders every once in a while. I opened it up enough to determine that it is the fan motor, still drawing air, but making the noise and shuddering occasionally.
A new one from Home Depot costs $129. Is it possible and/or worth it to find a replacement ventilation motor, or just replace the whole thing?
This is my first post, so please excuse me if this is not posted in the correct place, or if it is inappropriate in some way. Let me know!
Fredericch
fredericch is offline   Reply With Quote
Old 09-21-2011, 07:14 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Look at the motor....good chance you can buy a new one....the part # for the motor should be on the side....
Another option....go to HD....look at just vent fans....good chance a cheap one uses the same motor....might be cheaper to buy that and take the motor out of it.
Old 09-21-2011, 07:43 PM   #3
Electrical Contractor
kbsparky's Avatar
You might only need a new blower wheel. See if that is loose on the motor shaft. Blower wheels are usually less than $10.
-KB
Old 09-21-2011, 10:13 PM   #4
Thanks for the suggestions
Great idea to look for a fan-only model and switch out the motor. I'll look into that first, before opening up the motor and looking at parts. I'm not as DIY as that for the moment!
Fredericch
Tags
bath , fan , light , nutone , ventilation
