Numerous Breakers No Power? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 10:01 AM   #1
Numerous breakers no power?
Last week all the appliances in the kitchen stopped working but no breakers were tripped. I checked every outlet for loose wires and found the gfi had a detached hot =so i reattached it but the problem wasn't fixed.
The other day a family friend came over and removed the breaker panel and we noticed it wasn't just one breaker not working but about 5 or so have no power, the rest are fine.
He then moved one breaker that had no power down a couple slots to see if it would get power and sure enough it did.
Would anyone happen to know what could cause something like this to happen? Iv never personally seen this kind of problem before.
shockwavez is offline   Reply With Quote
Old 05-06-2013, 10:22 AM   #2
jproffer's Avatar
Rewards Points: 706
Every other breaker, vertically, is on the opposite leg of the main service. Sounds like you lost one leg.
None of the 220 appliances will work, if that is what happened...and every other breaker vertically on both sides will be dead.
You can check each one by touching one probe to the screw on the breaker and one to the neutral bar.
BE CAREFUL...part of the service is still hot and deadly.
jproffer is offline   Reply With Quote
Old 05-06-2013, 11:03 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Call the power company and have them check the incoming service.
Old 05-06-2013, 06:39 PM   #4
Called the power company and they came out and did a temporary fix. Looks like they ran wire from our meter to a neighbors till their able to come back and fix it later this week. Thank you all very much for the help. You guys are truly an amazing group of people
I will update this post when they come back and fix the problem. Below is a pic of what they did minus the pic of the wire going from the meter to my neighbors house.
Old 05-06-2013, 06:43 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,418
Same thing next door,......explained to them,
Bad news is you only have half your electrical working and I can't fix it
Good news is it'll be free and on the POCO
(Several years ago, the guys putting fiber optic down the street nicked one leg in our underground electric
MTN REMODEL LLC is online now   Reply With Quote
Old 05-06-2013, 07:15 PM   #6
Rewards Points: 150
we always recommend to our clients to call the POCO first
usair is offline   Reply With Quote
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires? tjnoff Electrical 84 12-09-2014 08:59 PM
Event Production power distribution, I want to do it right. mattvivsound Electrical 0 07-13-2012 08:54 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Two breakers to shut off power? brex Electrical 15 09-21-2010 08:10 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
