Numbers Of Wires In One Hole. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 06:37 PM   #1
Numbers of wires in one hole.
I went to my friends house and i noticed that they ran a 10-3 wire,12-2,14-2 in one hole through the bottom plate of the floor.
Im just curious, what size of hole would you need to run 3 14-2 wires in one hole in the studs.
latinomusician is offline   Reply With Quote
Old 06-12-2010, 07:52 PM   #2
Master Electrician
Rewards Points: 3,870
Originally Posted by latinomusician View Post
i went to my friends house and i noticed that they ran a 10-3 wire,12-2,14-2 in one hole through the bottom plate of the floor.
7/8".
brric is offline   Reply With Quote
Old 06-12-2010, 08:38 PM   #3
Rewards Points: 1,192
That would be covered under "Bundleling " in the N.E.C.
bobelectric is offline   Reply With Quote
Old 06-12-2010, 09:30 PM   #4
thanks for the response
Old 06-13-2010, 08:14 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Not really if it is a bottom plate. There is a good chance that these wires are not following the same path for any distance.
What would apply is the firestop derating rule in 334.80.
Speedy Petey is online now   Reply With Quote
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
installing an electrical outlet with 3 sets of wires + ground dsparks Electrical 7 07-08-2009 06:18 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 11:31 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
