Number Of Wires Into A Single Hole - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 01:23 PM   #1
Number of wires into a single hole
I am replacing the wire seen in the link below.
http://www.flickr.com/photos/93135998@N03/
I would like to run two wires through that same hole to add another ceiling light to the bedroom. The plan is to put a 14/2 wire and 14/3 (replacement) into that same hole (as seen in picture 2). 14/3 to ceiling fan, 14/2 to track lighting above bed.
Is this an okay plan according to code? Thanks in advance for any help.
dcs6f4 is offline   Reply With Quote
Old 02-12-2013, 03:50 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by dcs6f4 View Post
I am replacing the (frayed)wire seen in the link below.
I would like to run two wires through that same hole...
Is this an okay plan...
In less time than it took to write and post this Q...
you could have drilled a second small hole.
Try that.
Old 02-12-2013, 03:57 PM   #3
Try that.
Thanks for taking the time to respond, but that does not answer my question. Does anyone else know?
Old 02-12-2013, 05:35 PM   #4
Lic Elect/Inspector/CPO
Yes It is fine.
NJMarine is offline   Reply With Quote
Old 02-12-2013, 05:44 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would use a piece of flexible conduit to protect the wire from getting chewed again.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 06:28 PM   #6
jbfan's Avatar
Rewards Points: 140
According to his other post, he hit it with a drill.
Maximum wires in box for ceiling fan connection fan13 Electrical 10 07-29-2012 11:11 AM
How many wires through the same hole jheathma Electrical 9 01-06-2012 10:25 AM
Creating a hole in the wall to run wires, a good idea? RyanD General DIY Discussions 6 05-19-2009 04:30 PM
Max number of wires you can splice together firemanpato Electrical 12 01-10-2008 07:46 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 02:21 PM
