Number Of Things Per Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 11:39 AM   #1
Rewards Points: 178
Number of things per connection
Hi All - I recently remodeled the downstairs level of our split level home. When doing so I ran a few 12/3 (white/black/ground) from my electrical panel into my crawl space for future plans.
Its come time that I need a couple of outdoor receptacles. One in the front of the house one in the back. I also want to put up probably three motion sensor flood lights.
I have many more questions but we'll start here.
Can I run those items all off the same 12/3 line?
tb582 is offline   Reply With Quote
Old 05-03-2011, 12:15 PM   #2
Rewards Points: 1,538
How many watts for the floodlights. Really high powered tungsten halogen lights would probably mean you need a separate circuit for the three of them.
Old 05-03-2011, 01:10 PM   #3
Rewards Points: 282
yeah, do a load calc....but if i recall correctly i think no more than 10 fixtures/outlets on any circuit...i'm sure someone can give the exact NEC reference. but that is really a basic guidance and load calcs should always be done.
jcrack_corn is offline   Reply With Quote
Old 05-03-2011, 02:04 PM   #4
joed's Avatar
Rewards Points: 13,332
First thing is you don't have 12/3 you only have 12/2. 12/3 has a red wire. The ground doesn't count.
There is no limit in NEC about the number of device on a circuit. Unless you have some hogh wattage lights then there should be no problem with all them on the same circuit.
Old 05-03-2011, 03:42 PM   #5
Rewards Points: 178
Thanks - I haven't bought the flood lights yet but probably look at 300w lights.
Its acceptable to run the three lights and two receptacles off of the one 12/2 wire?
Old 05-03-2011, 04:11 PM   #6
Three 300 watt light fixtures for 900 watts out of the available 2400 watts (20 amps). THis is borderline. Most of the time you would not have a problem with the two outlet boxes on the same circuit, but there may be times at night when you don't have enough power and you trip the breaker.
Old 05-03-2011, 07:08 PM   #7
Lic Elect/Inspector/CPO
Per NEC you can only load a circuit to 80% which comes out 1920 watts.
Which is 16 amps
3- 300 watts lights equals 7.5 amps.
Since yiu know how many outlets you are adding, than load calc is 2 outlets x 180 va= 360 / 120- 3 amps
3 +7.5= 10.5 amps
You will be fine.
NJMarine is offline   Reply With Quote
Old 05-03-2011, 07:37 PM   #8
Master Electrician
Rewards Points: 3,918
Which is 16 amps
3 +7.5= 10.5 amps
You will be fine.
That is false. A 20 amp circuit can be loaded to 20 amps. The 80% rating is for continuous loads of 3 hours or more.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
jbfan (05-03-2011), Jim Port (05-06-2011)
Old 05-06-2011, 02:48 PM   #9
Rewards Points: 178
Thanks - I'm actually going with either two or three 200watt lights for the outside plus to
receptacles
Now how do I split all of these things off from my one 12/2 wire?
Old 05-06-2011, 03:18 PM   #10
Licensed electrician
Rewards Points: 1,766
Are you running power to the switches first or the receptacles? How many switches? Will the receptacles always be on or switch controlled?
I might suggest you read "Wiring Simplified" so you can see some wiring methods.
Old 05-06-2011, 03:26 PM   #11
Rewards Points: 178
Hmm excellent question! I haven't really thought about having the receptacles on a switch. If I do have switches I'll have one for each of the two receptacles.
Old 09-09-2011, 12:21 PM   #12
Rewards Points: 178
Getting back to this thread... I'm going to forgo the security lights for now and focus on the one outdoor receptacle. I'm going to get the following:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
I have questions on how to run my 12/2 wire which is in the crawl space and goes directly to the breaker box. Now most of my wiring is going to be through the crawl space so I can get a receptacle in the front of my house.
Now I have my 12/2 wire in the crawl space towards the back and there's not much slack. So I think I need a junction box right by that 12/2 wire which allow me to run the actual wire to the front of the house.
What type of junction box?
what type of wire?
I'm going through brick, what do I need to do here?
Old 09-09-2011, 01:05 PM   #13
I=E/R
a7ecorsair's Avatar
what type of wire?
Is the crawl space dry and sealed up with a concrete floor?
a7ecorsair is offline   Reply With Quote
Old 09-09-2011, 02:39 PM   #14
Rewards Points: 178
Dry, yes, but it has a dirt floor. Probably best not to chance it though
Old 09-12-2011, 08:55 AM   #15
Rewards Points: 178
bump
Flexible connection required for propane heater ? SteveB2175 Plumbing 8 04-07-2011 04:22 PM
Leaking Trap Connection bklusa1 Plumbing 3 02-17-2011 09:50 AM
vent hood electrical connection question cbendock Electrical 4 02-12-2011 10:33 PM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 08:41 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
