Old 01-09-2013, 06:58 PM   #1
Number of Receptacles in a Dormer Alcove?
Hello all!
I have been lurking on this site for the past 3 months as I have undertaken an entire remodel (right down to the studs). I am in the process of finishing up my rough electrical and am stuck with a concern regarding electrical receptacles.
The house has 1 dormer and the alcove dimensions are as follows:
36" wide at the window of the dormer
30" wide on both sides of the dormer
To make matters more complicated, the walls abutting the dormer have built in drawers from floor to ceiling that leave about 12" of wall space on both sides of the built ins.
(see diagram if this helps at all)
36"
______
30" l l 30"
l l
_12"_Built in_12"_l l_12"_Built in_12"_
My questions is, is it necessary by code to install one receptacle on each wall in the dormer (3 receptacles in a very tiny space)? Is one receptacle underneath the window adequate as the other 2 outlets would be within 6 feet? Are receptacles needed on the walls with the built ins?
Any help would be greatly appreciated and I would be happy to clarify anything.
Nick
chabot150 is offline   Reply With Quote
Old 01-09-2013, 07:00 PM   #2
Go back and add your location to your profile, no way to know what your codes are without it.
Old 01-09-2013, 07:01 PM   #3
Electrical Contractor
You don't say were you are from, but the codes states a recepracle shall be installed every 12 liner feet along an unbroken wall.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-09-2013, 07:04 PM   #4
location is updated, i apologize. West Hartford, CT
Old 01-09-2013, 09:08 PM   #5
is a dormer an unbroken wall?
Old 01-09-2013, 10:00 PM   #6
Licensed Electrician
k_buz's Avatar
Yes. From your description and dimensions, I would say you need 2 receptacles.
Not a fan of the new layout.
Old 01-09-2013, 10:43 PM   #7
JOATMON
ddawg16's Avatar
K buz....how does the NEC read? Isn't it something like....any wall over 2' must have a recept? An no more than 12' between recepticals?
Personally....I'm not taking chances....I even 'think' I might want a recept there....I'm putting in one.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 01-09-2013, 10:53 PM   #8
k_buz's Avatar
Any wall over 2'.
6' from any break in the wall.
12' after the first receptacle.
Basically, at any point on a wall, you have to be within 6' of a receptacle measured by linear wall space.
The Following User Says Thank You to k_buz For This Useful Post:
ddawg16 (01-09-2013)
Old 01-09-2013, 11:24 PM   #9
k_buz's Avatar
Just for added LOLs...I have had inspectors require a receptacle installed in a 6"x6" box out for a basement post.
electures (01-10-2013)
Asphalt shingles on vertical wall dormer helpplease! Roofing/Siding 2 12-13-2010 07:47 AM
3way half switched receptacles Rhyno973 Electrical 2 10-05-2010 03:33 PM
Surface Mounted Receptacles - Big Bulge? HandyMartin Electrical 13 08-10-2010 05:06 PM
Maximum number of receptacles on 15 amp circuit flati Electrical 11 03-07-2010 09:08 AM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 02:21 PM
