Number Of Junction Boxes On A Branch Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 07:37 AM   #1
j_sun's Avatar
Number of junction boxes on a branch circuit
Hi,
I am replacing the old k-n-t wiring in my home. Currently I am rewiring the outlets on my first floor as well as adding new ones to comply with current code.
The ceiling of my basement is unfinished so I have very easy access to the existing wiring as well to make new runs (there are some obstructions such as ductwork and plumbing of course).
My question is this:
Is there a limit to how many junction boxes can be used on a circuit/run?
I'm thinking it will be easier to just drop the wire from each receptacle straight down into the basement into a junction box that is directly below each one. I will then run the connecting wires between all the junction boxes.
Since I am primarily doing this myself without help, this seems like the easiest solution.
If there aren't any code restrictions on this are there any practical limitations or reasons not to do this?
Thanks,
Jason
j_sun is offline   Reply With Quote
Old 07-13-2011, 07:40 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
No restrictions on the number of JBs other than it increases the cost. Make sure the JBs are large enough for the number of conductors you plan.
Coastal South Carolina
Old 07-13-2011, 07:55 AM   #3
I=E/R
a7ecorsair's Avatar
Place one large JB under each room and feed it with power then run a cable to each location that will have a receptacle. You will have to watch the box fill and the number of wires that end up under a wire nut.
a7ecorsair is offline   Reply With Quote
Old 07-13-2011, 08:23 AM   #4
Master Electrician
Rewards Points: 3,964
The only issue would be if you are planning to finish the basement in the future the boxes must remain accessible.
As an additional thought, since you must fish cable into the wall anyway why not just go box to box instead of extra boxes in the basement. Fishing the walls is the hard part, not roping the cable between wall box locations.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
j_sun (07-13-2011)
Old 07-13-2011, 09:27 AM   #5
j_sun's Avatar
Brric - Thanks. I will be doing that as much as I can. The issue is that I'm doing most of this work at night after the kids are in bed so it is hard to get someone to help that late at night. There is one particular corner of the basement where going outlet-to-outlet will be pretty difficult. (It's hard to explain). I just wanted to make sure that there wouldn't be any limitations.
Thanks everyone!
Old 07-13-2011, 09:37 AM   #6
Licensed Pro
If you can fish one wire up to a receptacle, you should be able to fish two (in/out). Easiest way is to cut out the existing box, fish the wires, then install an old work box in the existing hole.
The Following User Says Thank You to HouseHelper For This Useful Post:
j_sun (07-13-2011)
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
markers for location of junction boxes under insulation kelley4180 Electrical 14 01-24-2010 09:24 PM
Can I change where power enters a branch circuit? RST Electrical 15 07-21-2009 07:38 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
