Number Of Devices On One Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 04:45 PM   #1
Rewards Points: 79
Number of devices on one circuit?
How many devices can be on one circuit. I am in upstate New York. Is there a limit like in Canada? I have six recessed cans, three under cab light sections and two pendants. All will be led except cfl's in the pendants.
Thanks,
Eric
Ebierley is offline   Reply With Quote
Old 02-10-2013, 04:53 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no set limit in the NEC. There may be a local or state limit. There is a limit (I think) of 11 in Canada.
The Following User Says Thank You to k_buz For This Useful Post:
Ebierley (02-10-2013)
Old 02-10-2013, 07:13 PM   #3
joed's Avatar
Rewards Points: 12,892
The limit in Canada is 12 outlets(lights, fans, receptacles, etc). No limit that I know of in NEC.
Old 02-10-2013, 07:27 PM   #4
Rewards Points: 1,192
Add up the allowable wattage on each fixture and go from there .
bobelectric is offline   Reply With Quote
Old 02-10-2013, 07:41 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Thanks,
Eric
In usa side there is no limit AFAIK., but in Canada side., Oui there is limit 12 devices. ( light socket , switch or receptlales )
The other thing when you sized the circuit with the recessed can we always go by the manufacter max wattage it will listed in the recessed cans reguardless of which type of lamps it being used.
Merci,
Marc
Old 02-11-2013, 09:03 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You are limited to one 15A general lighting circuit for every 600 sq ft of living space. There is no limit to the number of receptacles on each circuit. If supply lighting outlets, use the maximum wattage allowed for each fixture as a base line and go from there.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 02-11-2013, 05:40 PM   #7
Rewards Points: 79
So, does this mean that I can only have one lighting circuit for my 325sf kitchen?
Old 02-11-2013, 08:00 PM   #8
joed's Avatar
In Canada switches do not count as devices towards the 12 limit. They do not use power.
The Following User Says Thank You to joed For This Useful Post:
frenchelectrican (02-12-2013)
Old 02-12-2013, 01:04 AM   #9
I will remember this one for next time when someone ask me that question.
Merci,
Marc
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 09:38 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 10:37 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
